Getting Started with R2PRO
[hide]- 1 Introduction
- 2 specifications
- 3 Android
- 4 Linux
- 2. MicroUSB cable or usb to ttl cable if you need console debug message print, default baudrate is 1500000.
- 3. Windows or Linux PC.
Windows
- Maskrom Usb Download Mode(maskrom mode)
Install Image with SDcard
Boot Android from SDcard
- Create a sdcard for android boot is almost the same as create a firmware upgrade sdcard, only one difference is select "SD Boot" mode instead of "Upgrade Firmware". This process lasts about 8 minutes, then safely remove the SDcard, insert it into the r2pro board and power on.
- One thing to note is that make sure emmc is empty, you must erase it if flashed before. We recommend that use emmc for android boot because it is faster and more stable.
- 1. Get Android source code
$ git clone https://github.com/BPI-SINOVOIP/BPI-Rockchip-Android11 --depth=1
USB OTG Mode Switch
1. Tablet variant image
2. Box variant image
Dual Display
Touch Panel
- R2Pro hw design only have one group TP io, CN7, CN8, CN9 are all connect to it, so only one interface Touch Screen can be used at the same time. you can enable or disable it in dtb
&i2c1 { status = "okay" }
Custom Android Boot Logo
- 1. prepare two bmp format files, logo.bmp for uboot logo and logo_kernel.bmp for kernel logo.
- 2. there are two ways to replace the logo
- a. create and replace the logo with adb tool
- switch the otg port to enable adb, push the logo files to /sdcard/ directory.
$ adb push logo_kernel.bmp /sdcard/ $ adb push logo.bmp /sdcard/ $ adb root $ adb shell
- create logo.img
bananapi_r2pro:/ # cd /sdcard/ bananapi_r2pro:/sdcard # cat logo.bmp > logo.img && truncate -s %512 logo.img && cat logo_kernel.bmp >> logo.img
- flash logo.img to logo partition
bananapi_r2pro:/sdcard # dd if=logo.img of=/dev/block/by-name/logo 24301+1 records in 24301+1 records out 12442166 bytes (12 M) copied, 1.104449 s, 11 M/s
- reboot android
bananapi_r2pro:/sdcard # reboot
- b. create and the logo on Linux and replace it with RKDevTool
- create logo.img on Linux
$ cat logo.bmp > logo.img && truncate -s %512 logo.img && cat logo_kernel.bmp >> logo.img
- open RKDevTool.exe, Switch to the “Download Image” page, change the items as following, press REC/LOADER and power on or reset the board to enter loader download mode, then click Run to flash logo.img to logo partition.
IR Custom
Wlan&BT
- CN13 M.2 KEY E Slot is used for connect Wlan&BT adapter, the following WiFi Cards are tested and supported in default image
RTL8822CE WIFI/BT (PCIE+USB) RTL8822BE WIFI/BT (PCIE+USB) RTL8852BE WIFI/BT (PCIE+USB) RTL8822CS WIFI/BT (SDIO+UART) AP6256 WIFI/BT (SDIO+UART)
Install Google Play with Magisk
- 1. Download Magisk app
- 2. Download MagiskGapps package
- 3. Download device id app
- 4. Copy download apps and package to SDcard and plugin it to Bananapi R2pro.
- 1. Download the android source code
- 2. Apply this patch to enable build OpenGApps
diff --git a/device/rockchip/rk356x/bananapi_r2pro/BoardConfig.mk b/device/rockchip/rk356x/bananapi_r2pro/BoardConfig.mk index 3f17d3c0cc..bd8d1b3213 100755 --- a/device/rockchip/rk356x/bananapi_r2pro/BoardConfig.mk +++ b/device/rockchip/rk356x/bananapi_r2pro/BoardConfig.mk @@ -45,7 +45,7 @@ SF_PRIMARY_DISPLAY_ORIENTATION := 0 TARGET_ROCKCHIP_PCBATEST := false BOARD_HAS_FACTORY_TEST := false -BOARD_HAVE_OPENGAPPS := false +BOARD_HAVE_OPENGAPPS := true # increase super partition size for system, system_ext, vendor, product and odm # must be a multiple of its block size(65536)
- 6. Build the source code and flash the output image.
- 7. Install device id app and register your device for google play certification, more info please refer to the video above.
- 2. MicroUSB cable or usb to ttl cable if you need debug, default baudrate is 1500000.
Windows Driver install
Build Linux BSP Source Code
- 1. Get Linux source code
Dual Display
Note: eDP panel Display
Wlan&BT
