Getting Started with R2PRO
- 2. MicroUSB cable or usb to ttl cable if you need console debug message print, default baudrate is 1500000.
- 3. Windows or Linux PC.
Windows
- Maskrom Usb Download Mode(maskrom mode)
Install Image with SDcard
- 1. Get Android source code
$ git clone https://github.com/BPI-SINOVOIP/BPI-Rockchip-Android11 --depth=1
USB OTG Mode Switch
1. Tablet variant image
2. Box variant image
Dual Display
Touch Panel
- R2Pro hw design only have one group TP io, CN7, CN8, CN9 are all connect to it, so only one interface Touch Screen can be used at the same time. you can enable or disable it in dtb
&i2c1 {
status = "okay"
Custom Android Boot Logo
IR Custom
Wlan&BT
- CN13 M.2 KEY E Slot is used for connect Wlan&BT adapter, the following WiFi Cards are tested and supported in default image
RTL8822CE WIFI/BT (PCIE+USB) RTL8822BE WIFI/BT (PCIE+USB) RTL8852BE WIFI/BT (PCIE+USB) RTL8822CS WIFI/BT (SDIO+UART)
Install Google Play with Magisk
- 1. Download Magisk app
- 2. Download MagiskGapps package
- 3. Download device id app
- 4. Copy download apps and package to SDcard which plugin Bananapi R2pro.
- 5. Follow the process in the video to Install MagiskGapps
- 2. MicroUSB cable or usb to ttl cable if you need debug, default baudrate is 1500000.
Windows Driver install
Build Linux BSP Source Code
- 1. Get Linux source code
Dual Display
Note: eDP panel Display
Wlan&BT
