Getting Started with BPI-W3
The below steps is to flash linux release image into BPI-W3
- 2. MicroUSB cable or usb to ttl cable if you need debug, default baudrate is 1500000.
- 3. Windows or Linux PC.
Windows Driver install
- Error creating thumbnail: Unable to save thumbnail to destination
- Maskrom Usb Download Mode
- The download tool also show the download mode if device connected.
Install Image with SDcard
Build Linux BSP Source Code
- 1. Get Linux source code
Dual Display
Note: eDP panel Display
Wlan&BT
