BPI-Leaf-S3
Revision as of 02:20, 28 September 2022 by Wind (talk | contribs) (→Key Features)
BPI-Leaf-S3 with ESP32-S3
BPI-PicoW-S3 with ESP32-S3
BPI-Smart with ESP8266
BPI-Bit with ESP32
BPI-AI Kendryte K210 RISC-V
BPI-UNO32 with ESP32 design
The Banana Pi BPI-Leaf-S3 is a series of low-powered microcontrollers designed for IoT development and Maker DIY board.It supports 2.4 GHz Wi-Fi and Bluetooth® LE dual-mode wireless communication, the peripheral is compatible with low-power hardware design, and the power consumption is only 10uA in deep sleep mode.
The main controller supports two power supply inputs: USB and external 3.7V lithium battery, both can be interchangable freely. The battery could also be charged while USB is plugged in. Compact size, various interface, easy to use, and can be directly applied to low-power IoT projects.
The IO pins on BPI-Leaf-S3 are identical to the Espressif ESP32-S3-DevKitC-1, developers can add peripherals that are supported by DevKitC-1 onto the BPI-Leaf-S3, and can also combine it onto a breadboard.
  • ESP32-S3,Xtensa® 32 bit LX7
  • External PSRAM , FLASH
  • Ultra-low power 10uA
  • 1* JST SH 1mm 4-Pin Socket, support I2C
  • 1 * USB Type-C
  • 1 * MX 1.25mm 2-Pin Socket,support charging
  • 1 * Neopixel LED
ESP32-S3-DevKitC-1, BPI-Leaf-S3 Comparison
Dev Board BPI-Leaf-S3 ESP32-S3-DevKitC-1
GPIO Pins 36 36
3.3v Pins 3 3
5v Pins 1 1
GND Pins 4 4
ARGB LEDs 1 on GPIO48 1 on GPIO48
Chip Internal USB USB-C Connector x 1 MicroUSB Connector x 1
UART TTL to USB None CP2102-MicroUSB Connector x 1
External Battery Socket 3.7v Li-ion Battery dock None
Battery Charging 500mA Charging Current None
JST SH 1mm 4-Pin Socket 1 None
The BPI-Leaf-S3 dev board no longer equips traditional UART TTL to USB converter chip and its dedicated USB port. This is due to the ESP32-S3 chip's internal USB function were improved, supporting CDC-ACM virtual serial port and JTAG interface, which is capable of software development and firmware management feature, that makes the external converter chip redundant.
BPI-Leaf-S3 dev board is equipped with an I²C 4 pin dock, this stabalizes connection to other I²C peripherals. This dock is not only restricted to I²C connection, any module that requires a 3.3v pin, a GND pin, one or two data pin can also be connected to the Leaf-S3 via this 4 pin dock.
Espressif ESP32-S3
  • AI Acceleration Support: ESP32-S3 has additional support for vector instructions in the MCU, which provides acceleration for neural network computing and signal processing workloads. The software libraries for the above-mentioned optimized functions will become available very soon, in the form of updates to ESP-WHO and ESP-Skainet.
  • Rich Set of IO Peripherals: ESP32-S3 has 44 programmable GPIOs, namely 10 more GPIOs than those of ESP32. ESP32-S3 supports all the commonly-used peripherals, such as SPI, I2S, I2C, PWM, RMT, ADC and UART, SD/MMC host and TWAITM. In total, 14 GPIOs can be configured as capacitive touch input for HMI applications. Apart from all these peripherals, however, ESP32-S3 is also equipped with an ultra-low-power (ULP) core that supports multiple low-power modes in a variety of such use-cases.
  • Security:ESP32-S3 provides all the necessary security requirements for building securely connected devices, without requiring any external components. It supports AES-XTS-based flash encryption and RSA-based secure boot. In addition, ESP32-S3 has a digital signature peripheral and an HMAC module, which provide functionality that is similar to the hardware secure element, thus protecting the private or symmetric key from software attacks and identity theft. ESP32-S3 also has a “World Controller” peripheral that provides two fully-isolated execution environments, which enable the implementation of a trusted-execution environment or a privilege-separation scheme.
Hardware sketch map
Hardware Spec
BPI-Leaf-S3 Spec
SoC ESP32-S3,Xtensa® dual-core 32-bit LX7 microprocessor
Clock Frequency 240MHz MAX
Operating Temperature -40℃~+85℃
Internal ROM 384 KB
Internal SRAM 320 KB
Onboard FLASH ROM 4MB
On-chip PSRAM 2MB
WIFI IEEE 802.11 b/g/n ,2.4Ghz,150Mbps
Bluetooth Bluetooth 5 ,Bluetooth mesh
GPIO BPI-Leaf-S3 has led out 36 available gpios
ADC 2 × 12-bit SAR ADCs, up to 20 channels
Touch Sensor 14
SPI 4
I2C 2
I2S 2
LCD 1 × LCD interface (8-bit ~16-bit parallel RGB, I8080 and MOTO6800)
CAMERA 1 × DVP 8-bit ~16-bit camera interface
UART 3
PWM 8 channels 14 bits
MCPWM 2
USB 1 × full-speed USB OTG,female Type-C socket
USB Serial/JTAG controller 1,CDC-ACM ,JTAG
Temperature Sensor 1,ranging from -20 °C to 110 °C
SD/MMC 1 × SDIO host controller with 2 slots,SD 3.0,SD 3.01,SDIO 3.0,CE-ATA 1.1,MMC 4.41,eMMC 4.5,eMMC 4.51
TWAI® controller 1 ,compatible with ISO 11898-1 (CAN Specification 2.0)
General DMA controller (GDMA) 5 transmit channels and 5 receive channels
RMT 4 TX channels,4RX channels.Eight channels share a 384 x 32-bit RAM
Pulse Count Controller 4 independent pulse counters (units).Each unit consists of two independent channels
Timers 4 × 54-bit general-purpose timers. 1 × 52-bit system timer. 3 × watchdog timers
External crystal oscillator 40Mhz
RTC and Low­Power Management Power Management Unit (PMU) + Ultra-­Low-­Power Coprocessor(ULP)
Deep-sleep consumption current 10uA
Operating Voltage 3.3V
Input Voltage 3.3V~5.5V
USB charge Support
Maximum charging current 500mA
Neopixel LED 1
Hardware Dimensions
BPI-Leaf-S3 Dimensions
Pin spacing 2.54mm
Mounting hole spacing 23mm/ 62.25mm
Mounting hole size bore 2mm/outside 3mm
Motherboard size 26 × 65.25(mm)/1.02 x 2.57(inches)
board thickness 1.2mm
Peripheral Pin Configurations
BPI-Leaf-S3 GPIO Pin define
Peripheral Interface Signal Pin
ADC ADC1_CH0~9 GPIO 1~10
ADC2_CH0~9 GPIO 11~20
Touch sensor TOUCH1~14 GPIO 1~14
JTAG MTCK GPIO 39
MTDO GPIO 40
MTDI GPIO 41
MTMS GPIO 42
UART The pins are assigned by default, and can be redefined to any GPIO
U0RXD_in GPIO 44
U0CTS_in GPIO 16
U0DSR_in any GPIO
U0TXD_out GPIO43
U0RTS_out GPIO 15
U0DTR_out any GPIO
U1RXD_in GPIO 18
U1CTS_in GPIO 20
U1DSR_in any GPIO
U1TXD_out GPIO 17
U1RTS_out GPIO 19
U1DTR_out any GPIO
U2 any GPIO
I2C any GPIO
PWM any GPIO
I2S any GPIO
LCD any GPIO
CAMERA any GPIO
RMT any GPIO
SPI2/3 any GPIO
Pulse counter any GPIO
USB OTG D- GPIO 19(on-chip PHY)
D+ GPIO 20(on-chip PHY)
VP GPIO 42(external PHY)
VM GPIO 41(external PHY)
RCV GPIO21(external PHY)
OEN GPIO 40(external PHY)
VPO GPIO 39(external PHY)
VMO GPIO38(external PHY)
USB Serial/JTAG D- GPIO 19(on-chip PHY)
SD/MMC any GPIO
MCPWM any GPIO
TWAI any GPIO
Neopixel LED GPIO 48
Espressif ESP-IDF
API:
To enable your BPI-Leaf-S3 device to flash via USB-CDC.
There are two ways to enter Bootloader mode:
  1. Connect it to the computer via USB, hold BOOT button, press RST button once, then release BOOT button.
  2. Hold BOOT button while disconnected to power, connect to PC via USB, then release BOOT button.
The chip controls GPIO0 via BOOT button to choose between reset or cold boot.
Confirm the port of your BPI-Leaf-S3 device via device manager, it might display different port if you are on different modes.
MicroPython
Arduino
