BPI-Leaf-S3
![](/images/thumb/e/e5/Leaf-S3-incline-front.jpg/300x225x300px-Leaf-S3-incline-front.jpg.pagespeed.ic.IXa2N3W7_c.jpg)
![](/images/thumb/1/12/Leaf-S3-incline-back.jpg/300x225x300px-Leaf-S3-incline-back.jpg.pagespeed.ic.EDYd1a15ZG.jpg)
![](/images/thumb/6/69/Smart-01-03.gif/300px-Smart-01-03.gif)
![](/images/thumb/6/68/Webduino_gif.gif/300px-Webduino_gif.gif.pagespeed.ce.YHi9XrZ2gL.gif)
![](/images/thumb/4/47/ESP32_6.JPG/300x222x300px-ESP32_6.JPG.pagespeed.ic.1EbEnK4HRo.jpg)
The Banana Pi Leaf is a series of low-powered microcontrollers designed for IoT development.
It supports 2.4 GHz Wi-Fi and Bluetooth® LE dual-mode wireless communication, the peripheral is compatible with low-power hardware design, and the power consumption is only 10uA in deep sleep mode.
The main controller supports two power supply inputs: USB and external 3.7V lithium battery, both can be interchangable freely. The battery could also be charged while USB is plugged in. Compact size, various interface, easy to use, and can be directly applied to low-power IoT projects.
The IO pins on BPI-Leaf-S3 are identical to the Espressif ESP32-S3-DevKitC-1, developers can add peripherals that are supported by DevKitC-1 onto the BPI-Leaf-S3, and can also combine it onto a breadboard.
- ESP32-S3,Xtensa® 32 bit LX7
- External PSRAM , FLASH
- Ultra-low power 10uA
- 1* 4pin I2C connector
- 1 * USB Type-C
- 1 * 2pin battery connector,support charging
- 1 * Neopixel LED
ESP32-S3-DevKitC-1, BPI-Leaf-S3 Comparison
Dev Board | BPI-Leaf-S3 | ESP32-S3-DevKitC-1 |
GPIO Pins | 36 | 36 |
3.3v Pins | 3 | 3 |
5v Pins | 1 | 1 |
GND Pins | 4 | 4 |
ARGB LEDs | 1 on GPIO48 | 1 on GPIO48 |
Chip Internal USB | USB-C Connector x 1 | MicroUSB Connector x 1 |
UART TTL to USB | None | CP2102-MicroUSB Connector x 1 |
External Battery Socket | 3.7v Li-ion Battery dock | None |
Battery Charging | 500mA Charging Current | None |
I²C 4Pin Dock | 1 | None |
The BPI-Leaf-S3 dev board no longer equips traditional UART TTL to USB converter chip and its dedicated USB port. This is due to the ESP32-S3 chip's internal USB function were improved, supporting CDC-ACM virtual serial port and JTAG interface, which is capable of software development and firmware management feature, that makes the external converter chip redundant.
BPI-Leaf-S3 dev board is equipped with an I²C 4 pin dock, this stabalizes connection to other I²C peripherals. This dock is not only restricted to I²C connection, any module that requires a 3.3v pin, a GND pin, one or two data pin can also be connected to the Leaf-S3 via this 4 pin dock.
Espressif ESP32-S3
- Wi-Fi + Bluetooth 5 (LE) Wireless Connectivity: ESP32-S3 supports a 2.4 GHz Wi-Fi (802.11 b/g/n) with 40 MHz of bandwidth support. The Bluetooth Low Energy subsystem supports long range through Coded PHY and advertisement extension. It also supports higher transmission speed and data throughput, with 2 Mbps PHY. Both Wi-Fi and BLE have superior RF performance that is maintained even at high temperatures.
- AI Acceleration Support: ESP32-S3 has additional support for vector instructions in the MCU, which provides acceleration for neural network computing and signal processing workloads. The software libraries for the above-mentioned optimized functions will become available very soon, in the form of updates to ESP-WHO and ESP-Skainet.
- Rich Set of IO Peripherals: ESP32-S3 has 44 programmable GPIOs, namely 10 more GPIOs than those of ESP32. ESP32-S3 supports all the commonly-used peripherals, such as SPI, I2S, I2C, PWM, RMT, ADC and UART, SD/MMC host and TWAITM. In total, 14 GPIOs can be configured as capacitive touch input for HMI applications. Apart from all these peripherals, however, ESP32-S3 is also equipped with an ultra-low-power (ULP) core that supports multiple low-power modes in a variety of such use-cases.
- Security:ESP32-S3 provides all the necessary security requirements for building securely connected devices, without requiring any external components. It supports AES-XTS-based flash encryption and RSA-based secure boot. In addition, ESP32-S3 has a digital signature peripheral and an HMAC module, which provide functionality that is similar to the hardware secure element, thus protecting the private or symmetric key from software attacks and identity theft. ESP32-S3 also has a “World Controller” peripheral that provides two fully-isolated execution environments, which enable the implementation of a trusted-execution environment or a privilege-separation scheme.
Hardware sketch map
Hardware Spec
BPI-Leaf-S3 Spec | |
SoC | ESP32-S3,Xtensa® dual-core 32-bit LX7 microprocessor |
Clock Frequency | 240MHz MAX |
Operating Temperature | -40℃~+85℃ |
Internal ROM | 384 KB |
Internal SRAM | 320 KB |
Onboard FLASH ROM | 4MB |
On-chip PSRAM | 2MB |
WIFI | IEEE 802.11 b/g/n ,2.4Ghz,150Mbps |
Bluetooth | Bluetooth 5 ,Bluetooth mesh |
GPIO | BPI-Leaf-S3 has led out 36 available gpios |
ADC | 2 × 12-bit SAR ADCs, up to 20 channels |
Touch Sensor | 14 |
SPI | 4 |
I2C | 2 |
I2S | 2 |
LCD | 1 × LCD interface (8-bit ~16-bit parallel RGB, I8080 and MOTO6800) |
CAMERA | 1 × DVP 8-bit ~16-bit camera interface |
UART | 3 |
PWM | 8 channels 14 bits |
MCPWM | 2 |
USB | 1 × full-speed USB OTG,female Type-C socket |
USB Serial/JTAG controller | 1,CDC-ACM ,JTAG |
Temperature Sensor | 1,ranging from -20 °C to 110 °C |
SD/MMC | 1 × SDIO host controller with 2 slots,SD 3.0,SD 3.01,SDIO 3.0,CE-ATA 1.1,MMC 4.41,eMMC 4.5,eMMC 4.51 |
TWAI® controller | 1 ,compatible with ISO 11898-1 (CAN Specification 2.0) |
General DMA controller (GDMA) | 5 transmit channels and 5 receive channels |
RMT | 4 TX channels,4RX channels.Eight channels share a 384 x 32-bit RAM |
Pulse Count Controller | 4 independent pulse counters (units).Each unit consists of two independent channels |
Timers | 4 × 54-bit general-purpose timers. 1 × 52-bit system timer. 3 × watchdog timers |
External crystal oscillator | 40Mhz |
RTC and LowPower Management | Power Management Unit (PMU) + Ultra-Low-Power Coprocessor(ULP) |
Deep-sleep consumption current | 10uA |
Operating Voltage | 3.3V |
Input Voltage | 3.3V~5.5V |
Maximum discharge current | [email protected] DC/DC |
USB charge | Support |
Maximum charging current | 500mA |
Neopixel LED | 1 |
Hardware Dimensions
BPI-Leaf-S3 Dimensions | |
Pin spacing | 2.54mm |
Mounting hole spacing | 23mm/ 62.25mm |
Mounting hole size | bore 2mm/outside 3mm |
Motherboard size | 26 × 65.25(mm)/1.02 x 2.57(inches) |
board thickness | 1.2mm |
Peripheral Pin Configurations
BPI-Leaf-S3 GPIO Pin define | ||
Peripheral Interface | Signal | Pin |
ADC2_CH0~9 | GPIO 11~20 | |
Touch sensor | TOUCH1~14 | GPIO 1~14 |
JTAG | MTCK | GPIO 39 |
MTDO | GPIO 40 | |
MTDI | GPIO 41 | |
MTMS | GPIO 42 | |
UART | The pins are assigned by default, and can be redefined to any GPIO | |
U0RXD_in | GPIO 44 | |
U0CTS_in | GPIO 16 | |
U0DSR_in | any GPIO | |
U0TXD_out | GPIO43 | |
U0RTS_out | GPIO 15 | |
U0DTR_out | any GPIO | |
U1RXD_in | GPIO 18 | |
U1CTS_in | GPIO 20 | |
U1DSR_in | any GPIO | |
U1TXD_out | GPIO 17 | |
U1RTS_out | GPIO 19 | |
U1DTR_out | any GPIO | |
U2 | any GPIO | |
I2C | any GPIO | |
PWM | any GPIO | |
I2S | any GPIO | |
LCD | any GPIO | |
CAMERA | any GPIO | |
RMT | any GPIO | |
SPI0/1 | Used for FLASH and PSRAM | |
SPI2/3 | any GPIO | |
Pulse counter | any GPIO | |
USB OTG | D- | GPIO 19(on-chip PHY) |
D+ | GPIO 20(on-chip PHY) | |
VP | GPIO 42(external PHY) | |
VM | GPIO 41(external PHY) | |
RCV | GPIO21(external PHY) | |
OEN | GPIO 40(external PHY) | |
VPO | GPIO 39(external PHY) | |
VMO | GPIO38(external PHY) | |
USB Serial/JTAG | D- | GPIO 19(on-chip PHY) |
SD/MMC | any GPIO | |
MCPWM | any GPIO | |
TWAI | any GPIO | |
Neopixel LED | GPIO 48 |
Espressif ESP-IDF
- GitHub: ESP-IDF Eclipse Plugin README
- ESP-IDF VSCode Extension | GitHub: README | youtube: Quick User Guide for the ESP-IDF VSCode Extension
API:
To enable your BPI-Leaf-S3 device to flash via USB-CDC.
There are two ways to enter Bootloader mode:
- Connect it to the computer via USB, hold BOOT button, press RST button once, then release BOOT button.
- Hold BOOT button while disconnected to power, connect to PC via USB, then release BOOT button.
The chip controls GPIO0 via BOOT button to choose between reset or cold boot.
Confirm the port of your BPI-Leaf-S3 device via device manager, it might display different port if you are on different modes.
MicroPython
Arduino
- Arduino IDE download link | Install and configure the Arduino-ESP32 runtime environment
- GitHub: BPI-Leaf-S3 Arduino Getting Started
- Arduino-ESP32 APIs
- BPI-Leaf-S3 OLED displays potentiometer voltage and progress bar
- BPI-Leaf-S3 with ESP32-S3, use potentiometer to control neopixel steplessly
- BPI-Leaf-S3 with ESP32-S3, use key interrupts to control neopixel
- BPI-Leaf-S3 with ESP32-S3 & microPython Neopixel show
- Aliexpress shop : https://www.aliexpress.com/item/1005004428945296.html?spm=5261.ProductManageOnline.0.0.48af4edfYbyEoI
- Taobao shop : https://item.taobao.com/item.htm?spm=a2126o.success.0.0.29034831FGnLQW&id=677287234553
- OEM&OEM customized service : [email protected]
