Getting Started with R2PRO
Revision as of 00:41, 29 March 2022 by Dangku (talk | contribs) (Install Image with Usb Download Tool)
1. Double male USB data cable.
2. MicroUSB cable or usb to ttl cable if you need debug.
3. Windows or Linux PC.
4. Download the latest android image, and confirm that the md5 checksum is correct.
MaskRom Mode
Upgrade Mode
Windows
Download and install the RKDevTool
OTG Mode Switch
The top usb port is a usb 3.0 otg port, but without hw id pin, it only can be used as host or peripheral.The release image set host mode default, you can change it in Settings->Connected devices->USB Connect to PC, switch on is peripheral mode and switch off if host mode.
File:Otg mode.jpg
