Webduino firmware programming
Revision as of 07:12, 24 February 2019 by Sinovoip (talk | contribs) (→Auto Flash工具)
Firmware Bin file
File and burn position corresponding
FileName Function
bit_default.bin BPI-BIT Webduino standard firmware
bit_stable.bin BPI-BIT stable version Webduino firmware
boot_app0.bin Espressif-WROOM-32 master core program
partitions.bin BPI-BIT Webduino firmware partition table file
bootloader_dio_40m.bin Espressif-WROOM-32 bootloader(It is applicable to the DIO burning mode with a speed of 40MHz)
Firmware download address,please sure you download the newest version:Webduino for bpi:bit Firmware
Burning BPI:bit webduino firmware in Windows system
ESP FLASH DOWNLOAD TOOL
Tool download address:ESP Flash Download Tool
After downloading, unzip the archive and you will see an ESPFlashDownloadTool_v3.6.4.exe inside the folder. Open this shortcut and open an interface selection mode.
  • Double-click to open espflashdownloadtool_v3.6.4.exe and select ESP32 DownloadTool to start
Select ESP32 DownloadTool:
  • Check the four-line selection box, fill in the following four addresses 0x1000, 0x8000, 0xe000, 0x10000 in the box next to the column, and then select the corresponding file according to the following corresponding relations:
  • Verify the burn Settings, File and burn position corresponding to:
set file name Position
2 partitions.bin 0x8000
3 boot_app0.bin 0xe000
4 bit_default.bin 0x10000
- SpiFlashConfig:
SpiFlashConfig
1 CrystalFreq 40M
2 SPI SPEED 40MHz
3 SPI MODE DIO
4 FLASH SIZE 32Mbit
5 COM COMx(Fill in the port number assigned by the computer)
6 BAUD 1152000
Note : Where COMx is the serial number your system assigns to the board
During the burning process:
Finished:
Burn time is about 20s
  • Please refer to the following legend for details:
Auto Flash工具
We recommend that you first run the AutoErase. Exe tool to clear the bit board memory before burning the new firmware
  • AutoErase.exe double-click to run the script, and the latest serial port will be automatically selected (you can reconnect the bit board to the computer before burning). The script will automatically erase the memory of the bit board.
  • Double click autoflashwebduinobin.exe to run the script will automatically select the latest access to the serial port, burning the corresponding firmware file with the directory below, a total of four files are as follows:
partitions.bin
boot_app0.bin
webduino.bin
The burn end script restarts the board automatically. Completion of burning:
  • After using AutoFlash scripts tooling.You need to press and hold button A and then press the Rst button,Then release the Rst button and wait for the buzzer voice"Tick tock tock tock",Then release key A and wait for the board to start,Bitxxxx will be lit on the LED panel in the form of a running horse light, and then you can start using the bit board.
Burning BPI:bit webduino firmware in Linux system
will update soon
