Banana Pi BPI-CM5
BPI-CM5 Introduction
Banana Pi BPI-CM5 with A311D2 design
Banana Pi BPI-CM4 with A311D design
Banana Pi BPI-CM2 with Rockchip RK3568
Banana Pi BPI-CM5 with BPI-CM4 base board
BPI-CM4 Computer module and development Kit with base board
Banana Pi BPI-CM5 is a computer module with Amlogic A311D2 quad-core Cortex-A73 and quad-core Cortex-A53 SOC, Mali-G52 GPU MP8 GPU,4GB LPDDR4/LPDDR4x (Max 8G),16G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.
- 1. Amlogic A311D2,quad-core Cortex-A73 and quad-core Cortex-A53 SOC
- 2. Mali-G52 GPU MP8 GPU
- 3. 4GB LPDDR4/LPDDR4x (Max 8G)
- 4. 16G eMMC flash (Max 128G)
- 5. Designed with Board to Board connectors for enhanced stability same as RasPi CM4
- 6. One on-board Gigabit Ethernet
- 7. One PCIe2.0 interface expansion, can flexibly add related modules
- 8. One USB3.0 port up to 5Gbps
- 9. One USB2.0 high-speed USB/IO witch support USB OTG
- 10. Three HDMI2.1 receiver ports
- 11. one HDMI2.1 transmitter port with CEC
- 12. two 8-lane V-by-One output can support up to 4Kx2K resolution(Multiplexing with MIPI-DSI/eDP/LVDS)
- 13. two 4-lane MIPI-CSI camera interface with 16Mp ISP
- 14. support Android and Linux system.
- 15. Size: 55x40mm
BPI-CM5 Module Hardware interface
BPI-CM5 Module PIN Out define
BPI-CM5 moudule base board interface
Banana Pi BPI-CM5 SBC specifications
Same size as RPI CM4
Third part image
