Banana Pi BPI-M2S
Revision as of 09:09, 24 July 2023 by Sinovoip (talk | contribs)
BPI-M2S Introduction
BPI-M2S with Wifi&BT module
BananaPi BPI-M2S new design with Amlogic A311D, Quad core ARM Cortex-A73 and dual core ARM Cortex-A53 CPU ,ARM G52 MP4(6EE) GPU,NPU for AI at 5.0 TOPS, support Camera and MIPI-CSI interface ,HDMI output,2 Gigabit port, 4G RAM and 16 GB eMMC flash.
Amlogic S922X variant M2S board is 2G ram, 16G eMMC, not support npu, mipi panel and mipi camera.
  • 4GB LPDDR4 RAM
  • 16GB eMMC flash (Max 128G)
  • 2 Gigabit port
  • HDMI output
  • 40 PIN GPIO
Getting Started with M2S
BPI-M2S(A311D)Hardware interface
  • System Memory – 4GB LPDDR4
  • Video interfaces
HDMI 2.1 output up to 4Kp60
MIPI CSI connector for camera
  • Networking – 2x Gigabit Ethernet ports one via RTL8211F GbE transceiver, the other through RTL8111H PCIe to Gigabit Ethernet transceiver
  • USB – 1x USB 2.0 Type-A port, 1x USB Type-C port
  • Expansion – 40-pin GPIO header
  • Misc – 3x buttons
  • Dimensions – 65 x 65mm
PoE Wifi&BT
BPI-M2S 40PIN GPIO (CON2)
GPIO Pin Name Default :GPIO Function2 Function3
CON2-P01 VCC-3V3
CON2-P02 DCIN
CON2-P03 GPIOX_17 I2C_EE_M2_SDA BT_EN
CON2-P04 DCIN
CON2-P05 GPIOX_18 I2C_EE_M2_SCL BT_WAKE_HOST
CON2-P06 GND
CON2-P07 GPIOX_5 PWM_C WIFI_SD_CMD
CON2-P08 GPIOX_12 UART_EE_A_TX
CON2-P09 GND
CON2-P10 GPIOX_13 UART_EE_A_RX
CON2-P11 GPIOX_3 WIFI_SD_D3
CON2-P12 GPIOA_1 I2SB_SCLK
CON2-P13 GPIOX_4 WIFI_SD_CLK
CON2-P14 GND
CON2-P15 GPIOX_7 WIFI_WAKE_HOST
CON2-P16 GPIOX_0 WIFI_SD_D0
CON2-P17 VCC-3V3
CON2-P18 GPIOX_1 WIFI_SD_D1
CON2-P19 GPIOX_8 SPI_A_MOSI BTPCM_DIN
CON2-P20 GND
CON2-P21 GPIOX_9 SPI_A_MISO BTPCM_DOUT
CON2-P22 GPIOX_2 WIFI_SD_D2
CON2-P23 GPIOX_11 SPI_A_CLK BTPCM_CLK
CON2-P24 GPIOX_10 SPI_A_CS BTPCM_SYNC
CON2-P25 GND
CON2-P26 GPIOX_16 BT_32K
CON2-P27 GPIOH_5
CON2-P28 GPIOH_4
CON2-P29 GPIOX_14 BTUART_A_CTS_N
CON2-P30 GND
CON2-P31 GPIOX_15 BTUART_A_RTS_N
CON2-P32 GPIOX_19 HOST_WAKE_BT
CON2-P33 GPIOX_6 WIFI_PWREN
CON2-P34 GND
CON2-P35 GPIOA_2 I2SB_LRCLK
CON2-P36 GPIOAO_5 IR_IN
CON2-P37 GPIOA_0 I2S_MCLK_0
CON2-P38 GPIOA_4 I2SB_DOUT_DIN_1
CON2-P39 GND
CON2-P40 GPIOA_3 I2SB_DOUT_DIN_0
BPI-M2S Debug UART(CON1)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
BPI-M2S Camera(CN10)
CN10-P01 GND
CN10-P02 MIPI_CSI_D3N
CN10-P03 MIPI_CSI_D3P
CN10-P04 GND
CN10-P05 MIPI_CSI_D2N
CN10-P06 MIPI_CSI_D2P
CN10-P07 GND
CN10-P08 MIPI_CSI_CLKBN
CN10-P09 MIPI_CSI_CLKBP
CN10-P10 GND
CN10-P11 MIPI_CSI_D1N
CN10-P12 MIPI_CSI_D1P
CN10-P13 GND
CN10-P14 MIPI_CSI_D0N
CN10-P15 MIPI_CSI_D0P
CN10-P16 GND
CN10-P17 MIPI_CSI_CLKAN
CN10-P18 MIPI_CSI_CLKAP
CN10-P19 NC
CN10-P20 CAM0_MCLK
CN10-P21 CAM0_IRCUT
CN10-P22 CAM0_SCL
CN10-P23 CAM0_SDA
CN10-P24 CAM0_RESET
CN10-P25 VCC1V8_DOVDD
CN10-P26 GND
CN10-P27 GND
CN10-P28 VCC33
CN10-P29 VCC33
CN10-P30 VCC33
BPI-M2S LCD(CN9)
CN9-P01 MIPI_D0_N
CN9-P02 MIPI_D0_P
CN9-P03 MIPI_D1_N
CN9-P04 MIPI_D1_P
CN9-P05 MIPI_CLK_N
CN9-P06 MIPI_CLK_P
CN9-P07 MIPI_D2_N
CN9-P08 MIPI_D2_P
CN9-P09 MIPI_D3_N
CN9-P10 MIPI_D3_P
CN9-P11 TP_INT_3V3
CN9-P12 TP_RST_3V3
CN9-P13 I2C_M3_SCL_3V3
CN9-P14 I2C_M3_SDA_3V3
CN9-P15 LCD_BL_EN_3V3
CN9-P16 LCD_PWM_3V3
CN9-P17 GND
CN9-P18 GND
CN9-P19 VLCD_5V
CN9-P20 VLCD_5V
Baidu Cloud: https://pan.baidu.com/s/1rANGEB-1MLPCBXqOR5aYCg?pwd=8888 (pincode: 8888)
Google Drive: https://drive.google.com/drive/folders/1INIABp_MbB5UcwfqujTngGLOZN7YGuWp?usp=share_link
Baidu Cloud: https://pan.baidu.com/s/1eKLdicH0v_XBkUyX9aVRhw?pwd=ikme (pincode: ikme)
Google Drive:https://drive.google.com/file/d/1kZjWV91WUNK7rNJQw5HNUNMf5Lob2qsi/view?usp=share_link
How to flash Android Image
  • 2023-01-12-bpi-m2s-cm4-android9.img
Baidu Cloud: https://pan.baidu.com/s/1YVl0T9rSNqM3D0I1BRUr7A?pwd=8888 (pincode): 8888
Google Drive:https://drive.google.com/drive/folders/1u8flA6zsMOLnr75U4rvbph02z8YUKe2Y?usp=share_link
How to flash Linux Image
  • 2022-06-20-ubuntu-20.04-mate-desktop-bpi-m2s-aarch64-sd-emmc.img.zip
Baidu Cloud: https://pan.baidu.com/s/1kRukI-H-xliNqIqVacXWRw?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1P2YQUwdrREdiwidr8YtCvOdMmwLPerVu/view?usp=share_link
MD5:2945f225eadba1b350cd49f47817c0cd
  • 2022-06-20-ubuntu-20.04-server-bpi-m2s-aarch64-sd-emmc.img.zip
Baidu Cloud:https://pan.baidu.com/s/1UoYR0k9YH9SE_A-MpqZ2fg?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/file/d/1y0DUVDhLyhw_C7p6SD2q1EjOZLEV_c_w/view?usp=share_link
MD5:9b17a00cbc17c46e414a906e659e7ca2
  • 2022-06-20-debian-10-buster-bpi-m2s-aarch64-sd-emmc.img.zip
Baidu Cloud: https://pan.baidu.com/s/1TTsdyy5I7HLWS_Tptg7r2w?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/file/d/116ZydpggYpZ1WoSyVsc4QuchdIa3vGyI/view?usp=share_link
MD5:9d39558ad37e5da47d7d144c8afec45e
Third part image
Armbian unstable current build for Bananapi M2S
Armbian Image release on 2023-01-06
  • Armbian_23.02.0-trunk_Bananapim2s_bullseye_current_6.0.14_minimal.img.xz
Baidu Cloud:https://pan.baidu.com/s/1iEO_GcFa6Gy-cC0pnT4H3A?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1TDXuFliLZr4BY7NO5m_ijL4FxjsZNY8a?usp=share_link
Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-bullseye-current-minimal/14635
  • Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14_cinnamon_desktop.img.xz
Baidu Cloud:https://pan.baidu.com/s/1aqvVJXy1MqSVUHL-DD5Rpw?pwd=8888 (pincode: 8888)
Googel Drive:https://drive.google.com/drive/folders/1MPxwSg38uu0hVllUgqqmxKGsEMpfm-lM?usp=share_link
Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-jammy-current-cinnamon-desktop/14642
  • Armbian_23.02.0-trunk_Bananapim2s_bullseye_current_6.0.14.img.xz
Baidu Cloud:https://pan.baidu.com/s/1j0GVw3-ULFnWUFhwxr7muQ?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1Psku14DtTONHJD-73G58sD7CEoWfk4tT?usp=share_link
Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-bullseye-current/14634
  • Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14_minimal.img.xz
Baidu Cloud:https://pan.baidu.com/s/1MevqHbBTX8S-fsXuy9SahA?pwd=8888 (pincode: 8888)
Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-jammy-current-minimal/14639
  • Armbian_23.02.0-trunk_Bananapim2s_bullseye_current_6.0.14_xfce_desktop.img.xz
Baidu Cloud:https://pan.baidu.com/s/1ZcsXrj1lmYu6-ol6F0r-yA?pwd=8888
Google Drive:https://drive.google.com/drive/folders/1ugybAUZ4W2ov2Xy0yMsc9aTrGIBXVomI?usp=share_link
Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-bullseye-current-desktop/14636
  • Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14_gnome_desktop.img.xz
Baidu Cloud:https://pan.baidu.com/s/107kO-hGlyWMJFD9vpvKA-g?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/19mLva4UQgON8exl5xuF2T9HD-Wy2eH94?usp=share_link
Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-jammy-current-gnome-desktop/14640
  • 2023-01-6 Armbian_23.02.0-trunk_Bananapim2s_jammy_current_6.0.14.img.xz
Baidu Cloud:https://pan.baidu.com/s/1xPL6t4sbJjv3DzwPddZ2GQ?pwd=8888
Google Drive:https://drive.google.com/drive/folders/1vCpzC7sM42amOHqGcSjaZF6YovGg-xk3?usp=share_link
Discuss on the forum:https://forum.banana-pi.org/t/banana-pi-bpi-m2s-new-image-release-armbian-jammy-current/14637
easy to buy sample
