香蕉派 BPI-R2 Pro
BPI-R2 pro 介绍
Banana Pi BPI-R2 Pro 开源路由器采用Rockchip RK3568芯片方案设计, 板载2GB LPDDR4内存和16GB eMMC存储,支持2个USB 3.0接口,5千兆网口。M.2 Key-e和mini PCIe接口,2 mipi DSI接口(可通过软件切换LVDS), 1个CSI摄像头接口,1个HDMI输出.支持Android,Linux,OpenWRT系统
BPI-R2 Pro 尺寸接口与 Banana Pi BPI-R2 ,可以使用 BPI-R2 外壳.
- 瑞芯微(Rockchip RK3568 Quad-core ARM Cortex-A55 CPU
- Mali-G52 1-Core-2EE
- 2G LPDDR4 内存(可选 4G)
- Mini PCIE 接口 & M.2 key-e 接口
- 1 SATA 硬盘接口
- MicroSD 接口,最多256G SD卡
- 16G eMMC 存储( 可选16/32/64G)
- 2 MIPI 显示屏接口
- 1 CSI camera 摄像头接口
- 5 10/100/1000 Mb 千兆网口
- (2) USB 3.0 and (1) USB 2.0 otg 接口
瑞芯微(Rockchip) RK3568芯片介绍
快速上手
BPI-R2 Pro硬件接口示意图
| 香蕉派 BPI-R2 Pro | |
| CPU主控 | Rockchip RK3568 Quad-core ARM Cortex-A55 CPU 2GHz |
| GPU图形引擎 | Mali-G52 1-Core-2EE OpenGL ES3.2 Vu1kn 1.1 OpenCL 2.0 |
| Memory内存 | 2G DDR3 SDRAM (option 4G) |
| 存储 | Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 3.0 Port,SPI flash |
| 网络接口 | 5 x 10/100/1000 Mbit/s Ethernet |
| 显示(s) | 1 HDMI port, 2 DSI interface(1 DSI can change to LVDS by software) |
| Camera摄像头 | 1 CSI camera interfact |
| Video decoder(s) | H.265 HEVC/MVC Main10 Profile [email protected] up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps |
| Video encoder(s) | H.264/AVC BP/MP/[email protected],up to 1920x1080@100fps, H.265/HEVC [email protected], up to 1920x1080@100fps (4096x4096@10fps with TILE) |
| Audio Output(s) | HDMI & I2S & Speaker & Headphone |
| USB port | USB 3.0 PORT (x2), micro USB OTG (x1) |
| mini PCIE | 1 mini pcie interface & 1 M.2 key-e interface |
| Remote | IR Receiver (x1) |
| Power Source | 12 volt @2A via DC Power and/or Micro USB (OTG) |
| Size & Weight | 148 mm × 100.5mm 100g |
| OS | OpenWRT, Linux and others OS |
GPIO PIN 定义
开发资源
软件源代码
- linux-4.19.xx kernel BSP Source code on github :https://github.com/BPI-SINOVOIP/BPI-R2PRO-BSP/
- linux-5.10.66 kernel BSP Source code on github :https://github.com/BPI-SINOVOIP/BPI-R2PRO-BSP-5.10.x/
参考文档
- BPI-R2 Pro schematic diagram : https://drive.google.com/file/d/1aDOL8U6-4bxn7iB_MzCOgHoDhUu0wuQu/view?usp=sharing
- BPI-R2 Pro DXF file :https://drive.google.com/file/d/1N9AWJVHC4fZEko5_RIkc3pI0gK1I0XiV/view?usp=sharing
- RTL8367RB-VB-CG Switch chip datasheet:https://drive.google.com/file/d/1Rua-SRJLPoV0NLnvwJg-fopsD178KIts/view?usp=sharing
- BPI-R2 Pro CE,FCC,RoHS certificate : https://banana-pi.org/en/bpi-honor/
镜像发布
Note: the network disk include linux-4.19.xx and linux-5.10.66 kernel version, linux-5.10.66 kernel version can support DSA feature.
- All image for BPI-R2 Pro google : https://drive.google.com/drive/folders/1gHNGVL_uq8L4t987k-nzg6MKWDSmDcfC
- All image for BPI-R2 Pro : Baidu : https://pan.baidu.com/s/1u5bIp0fMJPre-j0bXGfDWA?pwd=i8q6 Pincode: i8q6
kernel linux-5.10.66 Release image, support DSA feature
Supported OS Note: OpenWRT, Debian10, Ubuntu 16.04. Ubuntu 20.04, Ubunutu 22.04, Ubunut OS support server version, desktop version, mate desktop version.
- kernel linux-5.10.66 image for BPI-R2 Pro : Baidu : https://pan.baidu.com/s/19B6AYrHfbIFgRytTpW8Mbg?pwd=6me6 Pincode: 6me6
AltLinux for Banana Pi BPI R2 pro
Armbian and LibreELEC for BPI-R2-pro
kernel linux-4.19.xx Release image
ubuntu 21.04
- ubuntu 21.04 linux kernel 4.19 image 2022-5-16 update, HDMI ,eDP and SDIO interface RTL8822CS WIFI module working fine
- google driver: https://drive.google.com/drive/folders/1pFayiLS3cS0idClUlvHzaySaJMb_AOrB
- baidu link: https://pan.baidu.com/s/1zUVDXOmEur3KFpNW_va7Wg?pwd=ci4u Pincode ci4u
- video and boot log:https://forum.banana-pi.org/t/banana-pi-bpi-r2-pro-openwrt-ubuntu-debian-linux-image/13158
- OpenWRT-21.02 linux kernel 4.19 image, 2022-5-16 update,HDMI ,eDP and SDIO interface RTL8822CS WIFI module working fine
- google driver: https://drive.google.com/drive/folders/10HzNC0pWhS8j3W7uaFQ5RGO7UK133Xt-
- baidu link: https://pan.baidu.com/s/1KUIJUB6nd_vKmRXms7NUKg?pwd=i72r Pincode: i72r
- Debian 10 linux kernel 4.19 image, 2022-5-16 update ,HDMI ,eDP and SDIO interface RTL8822CS WIFI module working fine
- google driver: https://drive.google.com/drive/folders/1LSJlHtkHC_Ua6zVgVI3BRJOVPUb6vWO6
- baidu link: https://pan.baidu.com/s/1rkVWlpeY0hIKPrIh3r7Nfw?pwd=n9gi Pincode: n9gi
- 2022-11-16 release, Android12-bpi-r2pro.img
- Google Drive: https://drive.google.com/file/d/1UZ-e6QJIB8ZU-rdGsCnDNaNR2pYHHvxA/view?usp=share_link
- Baidu Cloud: https://pan.baidu.com/s/1tQ5Fg47R0fpUajYpNIsJ3g?pwd=8888 (pincode: 8888)
- MD5:a7b5faf7818f1ab2d36253a5d3ca1d18
- Forum pthread:https://forum.banana-pi.org/t/bananapi-bpi-r2-pro-2022-11-16-android-12/14264
- 2022-09-06 release, Android11-atv-bpi-r2pro image
- Google Drive:https://drive.google.com/file/d/1E50R-8T3L42CUUYyv1eFw0Zvl1js3EuI/view?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/10N9ZgrgVJ3SiCoNxi681Hw?pwd=jmrn (pincode: jmrn)
- MD5: 82787086a4acf8e2d818b948670580cd
- 2022-09-06 release, Android11-bpi-r2pro image
- Google Drive:https://drive.google.com/file/d/1xY6ynrpJXIbo4vbz_P7KaiUAVLJQthzs/view?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/14iLchseyarxAKHCzrfnaEg?pwd=1gul (pincode:1gul)
- MD5: 83fa3ac4f0addcf3d47d20a58be39f50
- 2022-06-10 release, Android 11 with kernel 4.19.219, tablet variant image
- Google Drive: https://drive.google.com/file/d/1qiLZKU8_2O0hHgP25F0CRxv9MnSJlXpv/view?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/1EUiGaXuPxAkR69g7EOnVaw?pwd=4n6c (pincode: 4n6c)
- MD5: ebd336bad0c27c66ae65a4d38103bced
- 2022-06-10 release, Android 11 with kernel 4.19.219, atv variant image
- Google Drive: https://drive.google.com/file/d/104K7W1PX4OFvUtqNGHOnx6RZO49BrTZp/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1RbNf1dFqMxy1Dx_ysym82w?pwd=v4u8 (pincode: v4u8)
- MD5: 49506a8a3183ab189046b5e2e2833b87
