BPI-M2S Introduction
BPI-M2S with Wifi&BT module
BananaPi BPI-M2S new design with Amlogic A311D Quad core ARM Cortex-A73 and dual core ARM Cortex-A53 CPU ,ARM G52 MP4(6EE) GPU,NPU for AI at 5.0 TOPS, support Camera and MIPI-CSI interface ,HDMI output,2 Gigabit port . 4G RAM and 16 GB eMMC flash.
Amlogic S922X variant M2S board is not support npu, mipi panel and mipi camera.
NPU for AI :Next generation, deep-neural-network applications, at 5.0 TOPS
4GB LPDDR4 RAM
16GB eMMC flash (Max 128G)
support MIPI DSI Camera interface
support MIPI CSI Screen interface
2 Gigabit port
HDMI output
40 PIN GPIO
support Android and Linux system.
Getting Started with M2S
SoC – Amlogic A311D hexa-core processor with 4x Arm Cortex-A73 cores, 2x Arm Cortex-A53 cores, Arm Mali-G52 MP4 (6EE) GPU with OpenGL ES 3.2, Vulkan 1.0 and OpenCL 2.0 support, 5 TOPS NPU
System Memory – 4GB LPDDR4
Storage – 16GB eMMC flash (option up to 128GB), MicroSD card slot
Video interfaces
HDMI 2.1 output up to 4Kp60
MIPI CSI connector for camera
Networking – 2x Gigabit Ethernet ports one via RTL8211F GbE transceiver, the other through RTL8111H PCIe to Gigabit Ethernet transceiver
USB – 1x USB 2.0 Type-A port, 1x USB Type-C port
Expansion – 40-pin GPIO header
Debugging – 3-pin header for serial console
Misc – 3x buttons
Power Supply – Via USB-C port or pin header
Dimensions – 65 x 65mm
PoE Wifi&BT
BPI-M2S 40PIN GPIO (CON2)
GPIO Pin Name
Default :GPIO
Function2
Function3
CON2-P01
VCC-3V3
CON2-P02
DCIN
CON2-P03
GPIOX_17
I2C_EE_M2_SDA
BT_EN
CON2-P04
DCIN
CON2-P05
GPIOX_18
I2C_EE_M2_SCL
BT_WAKE_HOST
CON2-P06
GND
CON2-P07
GPIOX_5
PWM_C
WIFI_SD_CMD
CON2-P08
GPIOX_12
UART_EE_A_TX
CON2-P09
GND
CON2-P10
GPIOX_13
UART_EE_A_RX
CON2-P11
GPIOX_3
WIFI_SD_D3
CON2-P12
GPIOA_1
I2SB_SCLK
CON2-P13
GPIOX_4
WIFI_SD_CLK
CON2-P14
GND
CON2-P15
GPIOX_7
WIFI_WAKE_HOST
CON2-P16
GPIOX_0
WIFI_SD_D0
CON2-P17
VCC-3V3
CON2-P18
GPIOX_1
WIFI_SD_D1
CON2-P19
GPIOX_8
SPI_A_MOSI
BTPCM_DIN
CON2-P20
GND
CON2-P21
GPIOX_9
SPI_A_MISO
BTPCM_DOUT
CON2-P22
GPIOX_2
WIFI_SD_D2
CON2-P23
GPIOX_11
SPI_A_CLK
BTPCM_CLK
CON2-P24
GPIOX_10
SPI_A_CS
BTPCM_SYNC
CON2-P25
GND
CON2-P26
GPIOX_16
BT_32K
CON2-P27
GPIOH_5
CON2-P28
GPIOH_4
CON2-P29
GPIOX_14
BTUART_A_CTS_N
CON2-P30
GND
CON2-P31
GPIOX_15
BTUART_A_RTS_N
CON2-P32
GPIOX_19
HOST_WAKE_BT
CON2-P33
GPIOX_6
WIFI_PWREN
CON2-P34
GND
CON2-P35
GPIOA_2
I2SB_LRCLK
CON2-P36
GPIOAO_5
IR_IN
CON2-P37
GPIOA_0
I2S_MCLK_0
CON2-P38
GPIOA_4
I2SB_DOUT_DIN_1
CON2-P39
GND
CON2-P40
GPIOA_3
I2SB_DOUT_DIN_0
BPI-M2S Debug UART(CON1)
CON2-P1
GND
CON2-P2
UART0-RX
CON2-P3
UART0-TX
BPI-M2S Camera(CN10)
CSI Pin Name
Default Function
Function2:GPIO
CN10-P01
GND
CN10-P02
MIPI_CSI_D3N
CN10-P03
MIPI_CSI_D3P
CN10-P04
GND
CN10-P05
MIPI_CSI_D2N
CN10-P06
MIPI_CSI_D2P
CN10-P07
GND
CN10-P08
MIPI_CSI_CLKBN
CN10-P09
MIPI_CSI_CLKBP
CN10-P10
GND
CN10-P11
MIPI_CSI_D1N
CN10-P12
MIPI_CSI_D1P
CN10-P13
GND
CN10-P14
MIPI_CSI_D0N
CN10-P15
MIPI_CSI_D0P
CN10-P16
GND
CN10-P17
MIPI_CSI_CLKAN
CN10-P18
MIPI_CSI_CLKAP
CN10-P19
NC
CN10-P20
CAM0_MCLK
CN10-P21
CAM0_IRCUT
CN10-P22
CAM0_SCL
CN10-P23
CAM0_SDA
CN10-P24
CAM0_RESET
CN10-P25
VCC1V8_DOVDD
CN10-P26
GND
CN10-P27
GND
CN10-P28
VCC33
CN10-P29
VCC33
CN10-P30
VCC33
BPI-M2S LCD(CN9)
DSI Pin Name
Default Function
Function2:GPIO
CN9-P01
MIPI_D0_N
CN9-P02
MIPI_D0_P
CN9-P03
MIPI_D1_N
CN9-P04
MIPI_D1_P
CN9-P05
MIPI_CLK_N
CN9-P06
MIPI_CLK_P
CN9-P07
MIPI_D2_N
CN9-P08
MIPI_D2_P
CN9-P09
MIPI_D3_N
CN9-P10
MIPI_D3_P
CN9-P11
TP_INT_3V3
CN9-P12
TP_RST_3V3
CN9-P13
I2C_M3_SCL_3V3
CN9-P14
I2C_M3_SDA_3V3
CN9-P15
LCD_BL_EN_3V3
CN9-P16
LCD_PWM_3V3
CN9-P17
GND
CN9-P18
GND
CN9-P19
VLCD_5V
CN9-P20
VLCD_5V
How to flash Android Image
2022-06-13-bpi-m2s-android9.zip
Baidu Cloud: https://pan.baidu.com/s/1P-gtfw0aq6x21STJDhOpbg?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/file/d/14ZxrvWbCSMLIK0fEQjQSSFoDLBGmVjSm/view?usp=share_link
MD5: 9ed872402bc14ac2528990b2d6c41eff
How to flash Linux Image
2022-06-20-ubuntu-20.04-mate-desktop-bpi-m2s-aarch64-sd-emmc.img.zip
Baidu Cloud: https://pan.baidu.com/s/1kRukI-H-xliNqIqVacXWRw?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1P2YQUwdrREdiwidr8YtCvOdMmwLPerVu/view?usp=share_link
MD5:2945f225eadba1b350cd49f47817c0cd
2022-06-20-ubuntu-20.04-server-bpi-m2s-aarch64-sd-emmc.img.zip
Baidu Cloud:https://pan.baidu.com/s/1UoYR0k9YH9SE_A-MpqZ2fg?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/file/d/1y0DUVDhLyhw_C7p6SD2q1EjOZLEV_c_w/view?usp=share_link
MD5:9b17a00cbc17c46e414a906e659e7ca2
2022-06-20-debian-10-buster-bpi-m2s-aarch64-sd-emmc.img.zip
Baidu Cloud: https://pan.baidu.com/s/1TTsdyy5I7HLWS_Tptg7r2w?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/file/d/116ZydpggYpZ1WoSyVsc4QuchdIa3vGyI/view?usp=share_link
MD5:9d39558ad37e5da47d7d144c8afec45e
easy to buy sample
