BPI-CM4 Computer module and development Kit
About BPI-CM4 computer module
![](/images/thumb/3/31/Banana_Pi_BPI-CM4_1.jpg/300x300x300px-Banana_Pi_BPI-CM4_1.jpg.pagespeed.ic.vegDz3DSjR.jpg)
![](/images/thumb/1/12/BananaPi_BPI-CM4_base_board_1.jpg/300x300x300px-BananaPi_BPI-CM4_base_board_1.jpg.pagespeed.ic.6sGSfHusyK.jpg)
BPI-CM4 Computer module base board Kit with A311D design
![](/images/thumb/a/a7/Banana_Pi_BPI-CM4_2.jpg/300x225x300px-Banana_Pi_BPI-CM4_2.jpg.pagespeed.ic.OJ0Ny_1buV.jpg)
![](/images/thumb/d/df/Banana_Pi_BPI-CM4_9.jpg/300x200x300px-Banana_Pi_BPI-CM4_9.jpg.pagespeed.ic.s_P-lEX3jf.jpg)
![](/images/thumb/4/4f/Banana_Pi_BPI-M5_4.JPG/300x225x300px-Banana_Pi_BPI-M5_4.JPG.pagespeed.ic.5eDUNHGM8e.jpg)
![](/images/thumb/a/a9/BPI-M2_Pro_2.jpg/300x225x300px-BPI-M2_Pro_2.jpg.pagespeed.ic.QwYAEL6-Jj.jpg)
![](/images/thumb/6/6e/Banana_Pi_BPI-M2S_1.jpg/300x225x300px-Banana_Pi_BPI-M2S_1.jpg.pagespeed.ic.09oBHwAysc.jpg)
Banana Pi BPI-CM4 is a computer module with Amlogic A311D, same size as Raspberry Pi CM4 module ,it also features the same connection pins, which means that it should work with carrier boards designed for the Raspberry Pi CM4
Features
- Amlogic A311D 4 x ARM Cortex-A73 CPU cores,2 x ARM Cortex-A53 CPU cores
- ARM Mali-G52 MP4 graphics
- Neural Processing Unit with 5 TOPS performance.
- 4gb LPDDR4
- 16gb eMMC flash ,max support 128 gb
- Compatible with raspberry Pi CM4
- 1 x HDMI, 1 x CSI, 1x DSI interface(Raspberry Pi CM4 with 2)
Hardware inteface
Same sixe as RPI CM4
- BPI-M2S also with A311D code on guthub: https://github.com/BPI-SINOVOIP/BPI-M2S-bsp
documents
