Getting Started with R2PRO
Revision as of 01:12, 28 June 2022 by Dangku (talk | contribs) (Undo revision 12424 by Dangku (talk))
1. Double male USB data cable for image download or adb debug.
2. MicroUSB cable or usb to ttl cable if you need console debug message print, default baudrate is 1500000.
3. Windows or Linux PC.
4. Download the latest android image, and confirm that the md5 checksum is correct before flashing.
Windows
File:Driver install.PNG
This tool defaults language is Chinese. you can change it to English after extract the package. Open RKDevTool_Release_v2.84/config.ini with an text editor (like notepad). The starting lines are:
 #Language Selection: Selected=1(Chinese); Selected=2(English)
 [Language]
 Kinds=2
 Selected=1
 LangPath=Language\
  • Uboot Usb Download Mode (loader mode)
It's supposed to use this way if board already flashed a bootable uboot before.
  • Maskrom Usb Download Mode
Press the Recovery button or Maskrom button beside 3pin uart header and hold, connect the power adapter or press the RST button if power adapter already connected, about two seconds later, release the button. PC will Identify the device if RK usb driver installed correctly.
The download tool also show the download mode if device connected.
 $ unzip Linux_Upgrade_Tool_xxxx.zip
 $ cd Linux_UpgradeTool_xxxx
 $ sudo mv upgrade_tool /usr/local/bin
 $ sudo chown root:root /usr/local/bin/upgrade_tool
 $ sudo chmod a+x /usr/local/bin/upgrade_tool
 # upgrade again
Install Image with SDcard
1. Get Android source code
 $ git clone https://github.com/BPI-SINOVOIP/BPI-Rockchip-Android11 --depth=1
2. Build the Android Source code
USB OTG Mode Switch
1. Tablet variant image
Settings->Connected devices->USB Connect to PC, switch on is peripheral mode and switch off is host mode.
2. Box variant image
Go to Settings->Device Preferences->About, tap "Build" seven times to enable "Developer options" preference. Then back to Settings->Device Preferences->Developer options.Switch on is peripheral mode and switch off is host mode.
Dual Display
Touch Panel
R2Pro hw design only have one group TP io, CN7, CN8, CN9 are all connect to it, so only one interface Touch Screen can be used at the same time. you can enable or disable it in dtb
 &i2c1 {
         status = "okay"
IR Custom
Wlan&BT
CN13 M.2 KEY E Slot is used for connect Wlan&BT adapter, default image support RTL8822CE(PCIE+USB) and RTL8822CS(SDIO+UART).
1. Double male USB data cable for image download into EMMC
2. MicroUSB cable or usb to ttl cable if you need debug, default baudrate is 1500000.
4. Download the Linux Release Image Linux Release Image, and confirm that the md5 checksum is correct before flashing.
Windows Driver install
 [Language]
 Kinds=2
 Selected=2
 LangPath=Language\
Build Linux BSP Source Code
1. Get Linux source code
2. Build the Linux BSP Source code
Dual Display
  Note: All linux Image suuport dual display HDMI and eDP together, eDP only support 1920x1080.
  Note: HDMI Display
  Note: eDP panel Display
Wlan&BT
