BPI-CM4 Computer module and development Kit
Revision as of 23:00, 27 May 2022 by Sinovoip (talk | contribs) (Features)
About BPI-CM4 computer module
Banana Pi BPI-CM4 is a computer module with Amlogic A311D, same size asm Raspberry Pi CM4 module ,it also features the same connection pins, which means that it should work with carrier boards designed for the Raspberry Pi CM4
Features
  • . Amlogic A311D 4 x ARM Cortex-A73 CPU cores,2 x ARM Cortex-A53 CPU cores
2. ARM Mali-G52 MP4 graphics 3. Neural Processing Unit with 5 TOPS performance. 4. 2gb/4gb LPDDR4 5. 16gb eMMC flash ,max support 128 gb 6. Compatible with raspberry Pi CM4 7. 1 x HDMI, 1 x CSI, 1x DSI interface(Raspberry Pi CM4 with 2)
2.1 Gold finger interface core board 2.2 Development Kit
4 Resources 4.1 Source code 4.2 documents
