Getting Started with R2PRO
- 1. Double male USB data cable.
- 2. MicroUSB cable or usb to ttl cable if you need debug.
- 3. Windows or Linux PC.
- 4. Download the latest android image, and confirm that the md5 checksum is correct.
Windows
- Maskrom Usb Download Mode
Install Image with SDcard
- 1. Get Android source code
$ git clone https://github.com/Dangku/BPI-Rockchip-Android11 --depth=1
USB OTG Mode Switch
1. Tablet variant image
2. Box variant image
