Banana Pi BPI-CM4IO
BPI-CM4IO Introduction
Banana Pi BPI-CM4 with Amlogic A311D design
BananaPi BPI-CM4IO board is design for BPI-CM4 or RPi-CM4
  • support MIPI DSI Display interface
  • support MIPI CSI Camera interface
  • Minipcie
  • HDMI output
  • 26 PIN GPIO
  • USB TypeC OTG
  • TF Card slot
  • SIM Card Slot
  • RJ45(1 Gigabyte Ethernet)
  • USB 2.0 *2
  • UART Debug Interface
  • AD Key
  • Size:100x72mm
BPI-CM4 Module PIN Out define
26 PIN GPIO of Banana pi BPI-CM4IO
CON2-P01 VCC-3V3
CON2-P02 DCIN
CON2-P03 I2C1_SDA GPIOX-17
CON2-P04 DCIN
CON2-P05 I2C1_SCL GPIOX-18
CON2-P06 GND
CON2-P07 SPDIF_IN GPIOH_5
CON2-P08 UART_B_TX GPIOX-6
CON2-P09 GND
CON2-P10 UART_B_RX GPIOX-7
CON2-P11 GPIOAO-10
CON2-P12 I2SB_SCLK GPIOA-1
CON2-P13 SPDIF_OUT GPIOH-4
CON2-P14 GND
CON2-P15 IR-IN GPIOAO-5
CON2-P16 I2S_MCLK GPIOA-0
CON2-P17 VCC-3V3
CON2-P18 I2SB_LRCLK GPIOA-2
CON2-P19 SPI_A-MOSI GPIOX-8
CON2-P20 GND
CON2-P21 SPI_A-MISO GPIOX-9
CON2-P22 I2SC_DOUT_DIN_3 GPIOA-7
CON2-P23 SPI_A-SCK GPIOX-11
CON2-P24 SPI_A-SS0 GPIOX-10
CON2-P25 GND
CON2-P26 I2SC_DOUT_DIN_0 GPIOA-3
CON1-P1 GND
CON1-P2 UART0-RX
CON1-P3 UART0-TX
