Getting Started with W2
Overview Banana Pi BPI-W2
Overview: BPI-W2 Android 6.0
Debian 9 Linux Image Release 2018-09-18
BananaPI-W2 Ubuntu 18.04 New Image Release 2018-09-17
BananaPI-W2 Raspbian 9.4 New Image Release 2018-09-17
RPiTCv3_1.12-demo-bpi-w2-beta-2018-09-03
Read more: Banana Pi BPI-W2
  • Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
  • Using your USB-Serial Connect debug console on W2
Note: Debug Uart 3.3v TTL,Baud: 115200.
  • Default IP address for LAN port: 192.168.1.1
  • User name/password: pi/bananapi ,root/bananapi.
  • WIFI: Operwrt
Install Linux Image to SD card
Download the latest Linux Images
Note: Board SW4 switch to 1 for sd boot
1.Click on "Flash from file" to select image.
2.Click on "Select target" to select USB device.
3.Click on "Flash!" Start burning.
1.Install bpi-tools on your linux. If you can't access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
    $ apt-get install pv
2.After you download the image, insert your TF card into your Linux PC
    $ bpi-copy xxx.img /dev/sdx
3.After step 2, then you can insert your TF card into W2, and press power button setup W2.
Install Image to SD Card with Win32 Disk Imager On Windows
How to Format SD card on Windows
How to Install Image On SD Card with Win32 Disk Imager
Install Linux Image to EMMC
1.Prepare a SDcard with Linux image flashed and bootup board with this SDcard.
2.Unzip the image and copy it to a USB drive, plug the udisk to board and mount it.(If automatically mounted, ignore this step)
   mount /dev/sdx /mnt
3.There are two ways to install the linux image to board.
  • Install with dd command.
   sudo dd if=/mnt/xxx.bpi-w2-xxx.img of=/dev/mmcblk0 bs=10M status=noxfer
  • Install the linux image in udisk with bpi-tools command
   sudo bpi-copy xxx-bpi-w2-xxx.img.zip /dev/mmcblk0
4.After download complete, power off safely and eject the SDcard.
Install Android image
Download the latest Android image
Download BPI-W2 USB flash tool
Note:
1. BPI-W2 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform.
2. Make sure SW4 switch to '0' for emmc boot.
3. Read w2_android_usb_download_tool/document/bananapi_w2_usb_download_tool_guide.doc before flashing image.
How to support your IR Remote
How to custom your Boot Logo
GPIO
PWM Control
SATA
1. Mount dev on W2
  • "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
  • iperf3 -c [server]
  • iperf3 -u -c [server]
  • iperf3 -s
WiFi & BT
STA
  • ip link set wlan0 up
network={
ssid="ssid"
psk="password"
priority=1
  • dhclient wlan0
AP
Developing
Develop 4G module with W2
GPU
  • Execute "glmark2-es" to start OpenGL test
  • glmark2 Score: 30
Make your own image
