Getting Started with P2-Zero
- Read more about : Banana Pi BPI-P2 Zero
BPI-P2 Zero
- CPU: Allwinner H2+, Quad-core Cortex-A7
- 512MB DDR 3 SDRAM
- Mini HDMI
- 40 PIN GPIO, It includes UART, SPI, I2C, IO etc
- 100M LAN
- 8G eMMC flash onboard
Load your first Android image on M1
1.You could download latest image from our forum. 2.Put your TF card into a TF-USB adapter, and then plug adapter in your Windows PC usb interface. 3.Prepare your image, and download image burning tools PhoenixCard.exe. 4.Use "PhoenixCard.exe" to burn android image to TF card.![]()
* Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System * Using your USB-Serial Connect debug console on P2 Zero
Install Linux Image on P2 Zero
Install Image to SDcard on Linux PC with bpi-tools
- 1. Install bpi-tools on your system
- If you can't access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
- 2. Insert your SDcard into your PC
$ bpi-copy xxx.img /dev/sdx
- 4.After success install, power off the board, eject the sdcard and poweron with emmc boot.
Update your image
- 1. Get the p2 zero bsp source code
$ git clone https://github.com/BPI-SINOVOIP/BPI-M2P-bsp-4.4
- 2. Build the source code according to the README.md, and update the packages to the sdcard with bpi image flashed.
- 2. Copy Linux image to udisk, plug the udisk to OTG Port(via USB-to-MicroUSB) of the board and mount it.
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-p2zero-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
- 4. Install the linux image in udisk with bpi-tools command
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-p2zero-xxx.img.zip /dev/mmcblk0
How to create an image
OTG
1. On M2 Zero console:
2. On PC terminal:
EMac
- Use iperf3 to test network
- Execute "bluetoothctl"
- Execute these commands:
network={
ssid="ssid"
psk="password"
priority=1
We use HDF5640 camara.
Display
parameters meaning:
BPI-Tools
Install Bpi-tools
Update Bpi-tools
- Execute "bpi-tools"
- cd /usr/local/bin
How to Update WiringPi
