Banana Pi BPI-M4
- 8G eMMC flash (max 64 GB)
- USB 2.0 TYPE C
- PoE function support
| HardWare Specification of Banana pi BPI-M4 | |||
| CPU | Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit | ||
| GPU | Mali 470 MP4 GPU OpenGL ES 1.1/2.0 | ||
| Memory | 1 GB DDR4 (option 2 GB) | ||
| Storage | MicroSD slot with support for up to 256GB expansion and 8G eMMC flash with support for up to 64GB | ||
| Network | 10/100 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2 | ||
| Video Output(s) | HDMI port and multi-channel audio output support 1080P H.264 H.265 2K/4K | ||
| Audio Output(s) | 3.5mm jack and HDMI | ||
| PCIE | M.2 Key E slot PCIE 2.0 and USB 2.0 | ||
| USB ports | USB 2.0 PORT (x4), USB 2.0 TYPE C(x1) | ||
| Power Source | 5 volt @2A via Micro USB (TYPE C) or PoE support | ||
| OS | Android and Linux | ||
Banana Pi BPI-M4 has a 40-pin GPIO header Following is the Banana Pi GPIO Pinout:
| 40 PIN GPIO of Banana pi BPI-M4 | |||
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | DCIN | ||
| CON1-P03 | I2C1_SDA | GPIO-17 | |
| CON1-P04 | DCIN | ||
| CON1-P05 | I2C1_SCL | GPIO-16 | |
| CON1-P06 | GND | ||
| CON1-P07 | PWM1 | GPIO-21 | |
| CON1-P08 | UR1_TX | GPIO-9 | |
| CON1-P09 | GND | ||
| CON1-P10 | UR1_RX | GPIO-8 | |
| CON1-P11 | SDIO-D0 | GPIO-42 | |
| CON1-P12 | AIO_BCK | GPIO-3 | |
| CON1-P13 | SDIO-D1 | GPIO-43 | |
| CON1-P14 | GND | ||
| CON1-P15 | SDIO-D2 | GPIO-44 | |
| CON1-P16 | UR1_RTS | GPIO-11 | |
| CON1-P17 | VCC-3V3 | ||
| CON1-P18 | UR1_CTS | GPIO-10 | |
| CON1-P19 | GSPI-MOSI | GPIO-31 | |
| CON1-P20 | GND | ||
| CON1-P21 | GSPI-MISO | GPIO-18 | |
| CON1-P22 | GPIO-47 | GPIO-47 | |
| CON1-P23 | GSPI-SCK | GPIO-19 | |
| CON1-P24 | GSPI-CS | GPIO-20 | |
| CON1-P25 | GND | ||
| CON1-P26 | PWM2 | GPIO-22 | |
| CON1-P27 | SDIO-D3 | GPIO-45 | |
| CON1-P28 | PWM3 | GPIO-23 | |
| CON1-P29 | SDIO-CLK | GPIO-41 | |
| CON1-P30 | GND | ||
| CON1-P31 | SDIO-CMD | GPIO-40 | |
| CON1-P32 | SPDIF | GPIO-50 | |
| CON1-P33 | AIO_CK | GPIO-4 | |
| CON1-P34 | GND | ||
| CON1-P35 | AIO_LRCK | GPIO-2 | |
| CON1-P36 | GPIO-53 | GPIO-53 | |
| CON1-P37 | GPIO-34 | GPIO-34 | |
| CON1-P38 | AI_SD | GPIO-5 | |
| CON1-P39 | GND | ||
| CON1-P40 | AO_SD | GPIO-6 | |
| Uart PIN define of Banana pi BPI-M4 | |||
| CON2-P1 | GND | ||
| CON2-P2 | UART0-RX | ||
| CON2-P3 | UART0-TX | ||
- Banana Pi BPI-M4: How to get I2C and SPI running (tutorial):https://forum.banana-pi.org/t/banana-pi-bpi-m4-how-to-get-i2c-and-spi-running-tutorial/12824/6
- Supports Banana Pi BPI-M4 (RTD1395) (Kernel 4.9.119)
- Source code on github: https://github.com/BPI-SINOVOIP/BPI-M4-bsp
documents
- BPI-M4 schematic diagram:
- google driver:https://drive.google.com/file/d/1A6pj8Y9Ru1_qfMapIdiQnMavEs5xzN5H/view?usp=sharing
- Baidu cloud:https://pan.baidu.com/s/1mnn51dwBV5uxpNheBD4vJA pincode: t6cd
- Banana Pi BPI-M4 CE,FCC,RoHS Certification :http://forum.banana-pi.org/t/banana-pi-bpi-m4-ce-fcc-rohs-certification/9520
- Realtek RTD1395 chip datasheet : https://drive.google.com/file/d/1Jt8qUwEjLinMqURMftC3db0Xg9MIWIhu/view?usp=sharing
- BPI-M4 DXF file download
- google driver: https://drive.google.com/file/d/1xK-DAjdjXiY7BgGcmq7x-aL5g6djznqT/view?usp=sharing
- baidu cloud : https://pan.baidu.com/s/1bSZFMJ2lD_zuQru6Lf27RQ Pincode: 6pb8
- Banana Pi BPI-M4 Android 8 1 1 demo ,power by raspberry Pi PoE module :https://www.youtube.com/watch?v=aEZ9tSJ-Oao&feature=youtu.be
- Banana Pi BPI-M4 video play h264 4K under Linux with gst-launch-1.0;https://www.youtube.com/watch?v=PwdyGX3tqvo&feature=youtu.be&fbclid=IwAR3AHOgFo4I3bDRl3oLtQXFBj2NUCYBR9GJnEo3tZzpNPKhjE9eKms7JVsQ
- Banana Pi BPI-M4 digital photo download:https://drive.google.com/file/d/1lD9vOhdZMqHFilTPPHY80My0biszvW8r/view?usp=sharing
- BPI-M4 SBC bench test :http://forum.banana-pi.org/t/bpi-m4-sbc-bench-test/9469
- Banana pi BPI-M4: m.2 extension board with nvme ssd :http://forum.banana-pi.org/t/bpi-m4-m-2-extension-board-with-nvme-ssd/11999
- Banana Pi BPI-M4 Review: https://www.magazinmehatronika.com/en/banana-pi-m4-review/
- BPI-M4 USB host dying (uvcvideo and usb rtl8821cu) (solution):https://forum.banana-pi.org/t/bpi-m4-usb-host-dying-uvcvideo-and-usb-rtl8821cu-solution/13210
Android Images
- 2020-10-20 update, Android 8.1 with kernel 4.9.119.
- Note: BPI-M4 Android8 image is only support 2GB ddr board because 1GB ddr is not stable and smooth for Android8
Linux Images
Ubuntu Mate 18.04, Ubuntu Server 16.04, Raspbian Stretch
- 2020-05-18 update, Kernel 4.9.119
Ubuntu linux
Debian linux
- FAQ
- Debian 10 buster (32bit)
- FAQ
- FAQ
Raspbian Linux
- FAQ
AArch Linux
- Fetures Map:
- AArch64 Linux Lite
- Fetures Map:
- FAQ
- FAQ
