Banana Pi BPI-M2 ZERO
Banana Pi BPI-M1 with Allwinner A20 chip
Banana Pi BPI-M1+ with Allwinner A20 chip
Banana Pi BPI-P2 Zero with Allwinner H3 chip
Banana Pi BPI-M2+ with Allwinner H3 chip
Banana Pi BPI-M2M with Allwinner R16 chip design
Banana Pi BPI-M2 Berry with Allwinner A40i
Banana Pi BPI-M2U with Allwinner A40i
Banana Pi BPI-M64 with Allwinner A64 chip design
Banana Pi BPI-M3 with Allwinner A83T chip design
As Allwinner H2+ chip is EOL, so BPI-M2 Zero will use H3 chip defaults. but image for H2+ also support H3, so all image is same. support H2+ and H3 chip.
  • CPU: Allwinner H3/H2+, Quad-core Cortex-A7.
  • 512MB DDR 3 SDRAM.
  • WiFi (AP6212/K016) & BT onboard.
  • Mini HDMI.
CPU Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core
Onboard WIFI K016/SDIO AP6212(option AP6181、AP6335) K016/SDIO AP6212(option AP6181、AP6335) 802.11n wireless, BT 4.1
IR N/A N/A N/A
Supported OS android linux android linux Linux
Weight 30g 15g 9g
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI0-SDA PA12-EINT12
CON2-P04 VCC-5V
CON2-P05 TWI0-SCK PA11-EINT11
CON2-P06 GND
CON2-P07 PWM1 PA6-EINT6
CON2-P09 GND
CON2-P11 UART2-RX PA1-EINT1
CON2-P13 UART2-TX PA0-EINT0
CON2-P14 GND
CON2-P15 UART2-CTS PA3-EINT3
CON2-P17 VCC-3V3
CON2-P18 PC4 PC4
CON2-P19 SPI0-MOSI PC0
CON2-P20 GND
CON2-P21 SPI0-MISO PC1
CON2-P22 UART2-RTS PA2-EINT2
CON2-P23 SPI0-CLK PC2
CON2-P24 SPI0-CS PC3
CON2-P25 GND
CON2-P26 PC7 PC7
CON2-P27 TWI1-SDA PA19-EINT19
CON2-P28 TWI1-SCK PA18-EINT18
CON2-P29 PA7-EINT7 PA7-EINT7
CON2-P30 GND
CON2-P31 PA8-EINT8 PA8-EINT8
CON2-P33 PA9-EINT9 PA9-EINT9
CON2-P34 GND
CON2-P39 GND
code on github: https://github.com/TuryRx/Banana-pi-m2-zero-GPIO
code on github:https://github.com/bontango/BPI-WiringPi2
CN3-P01 NC
CN3-P02 GND
CN3-P03 CSI0-SDA PE13
CN3-P04 CSI0-AVDD
CN3-P05 CSI0-SCK PE12
CN3-P06 CSI0-Reset PE14
CN3-P07 CSI0-VSYNC PE3
CN3-P08 CSI0-PWDN PE15
CN3-P09 CSI0-HSYNC PE2
CN3-P10 CSI0-DVDD
CN3-P11 CSI0-DOVDD
CN3-P12 CSI0-D7 PE11
CN3-P13 CSI0-MCLK PE1
CN3-P14 CSI0-D6 PE10
CN3-P15 GND
CN3-P16 CSI0-D5 PE9
CN3-P17 CSI0-PCLK PE0
CN3-P18 CSI0-D4 PE8
CN3-P19 CSI0-D0 PE4
CN3-P20 CSI0-D3 PE7
CN3-P21 CSI0-D1 PE5
CN3-P22 CSI0-D2 PE6
CN3-P23 GND
CN3-P24 CSI0-DOVDD
CON3 P03 UART0-TXD PA4
CON3 P02 UART0-RXD PA5
CON3 P01 GND
PIN define:
schematic diagram:
test
Zero power with GPIO 5V input
  • Android 4.4 source code
  • Linux source code
  • Banana Pi M2 Zero GPIO with Python
https://github.com/rlatn1234/pyGPIO2
  • Imagenes Ubuntu estables para Banana Pi M2 Zero:
duscuss on forum : https://forum.banana-pi.org/t/gpio-imagenes-ubuntu-banana-pi-bpi-m2-zero/13247
  • 2018-07-09 update Android 4.4, kernel 3.4
Forum pthread:
  • 2017-11-12 update Android 4.4, kernel 3.4
Forum pthread:
  • 2020-04-28 update, Debian 9, Rasbian Stretch, Ubuntu 16.04 Mate Desktop and Ubuntu 16.04 Server, base on kernel 4.4
Arch Linux
  • Banana Pi BPI-M2 Zero Instalacion y Configuracion de Arch Linux
https://github.com/TuryRx/Banana-pi-m2-zero-Arch-Linux
discuss on forum : https://forum.banana-pi.org/t/instalacion-y-configuracion-de-arch-linux-en-bpi-m2-zero/13192
  • Armbian_23.05.0-trunk_Bananapim2zero_bullseye_current_6.1.24_mate_desktop.img
Google Drive:https://drive.google.com/file/d/1Q16Xi6PMSGCW9FxSecIvvf_5rnkqgNsM/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/16vL43zl8zINraHLtnbzlhg?pwd=8888 (pincode: 8888)
  • 2023-07-06 Armbian_kernel6.1.24, support emmc, usb wifi, emac
Google Drive:https://drive.google.com/drive/folders/1Y2RUA11B8zANc7aozdXcAJ782F5c4Pdv?usp=drive_link
Baidu Cloud:https://pan.baidu.com/s/1il64jearOr7xh25YcqOkxw?pwd=8888 (pincode:8888)
  • 2022-12-06 Armbian_22.11.0-trunk_Bananapim2zero_bullseye_edge_6.0.9.img.xz
Google Drive:https://drive.google.com/file/d/11crpUOyLDn49eP76bszXfJiF2D7c0L-8/view?usp=share_link
Baidu Cloud:https://pan.baidu.com/s/1YLuBICd4mVOoTZzoWaEjCw?pwd=8888 (pincode: 8888)
Discuss on forum: https://forum.banana-pi.org/t/bananapi-bpi-m2-zero-new-image-release-armbian-bullseye/14448
RetroPie
retrorangepi
Raspbian
fourm: http://forum.banana-pi.org/t/banana-pi-bpi-m2-zero-new-image-2020-04-10-raspbian-jessie-ap6212-bpi-m2z-sd-emmc-image/10978
  • 2019-04-30 update Raspbian Stretch, kernel 3.4
forum: http://forum.banana-pi.org/t/bananapi-bpi-m2z-bpi-p2-zero-h2-new-images-reapbian9-4-ubuntu16-04-release-2019-04-30/9166
  • 2018-07-09 update Raspbian Stretch, kernel 3.4
Google Drive: https://drive.google.com/file/d/1XMVCWCWoWmhzL-c89rkqzZVE_k7xYCvd/view
baidu Drive: https://pan.baidu.com/s/1ahXv3Hl7Dst7uBwz60pcrg 2
forum: http://forum.banana-pi.org/t/bananapi-bpi-m2z-h2-new-image-raspbian-ubuntu-release-2018-07-09/6221
  • 2022-09-27-Armbian_22.11.0-trunk_jammy_edge_lubuntu_5.19.6-qt5-swap-bpi-P2z-M2Z-10804MB
Google Drive: https://drive.google.com/file/d/1_rsQthyCU4HaN8tcGsPMvzt6dMwaRI-A/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/1RKJzzpMOHnFW0nj8I-NJIA?pwd=rk22 (pincode: rk22)
MD5:f4dfbe234c21a6038f50f699780d4e03
  • 2022-09-07 Armbian_22.11.0-trunk_Bananapim2zero_jammy_edge_5.19.6_xfce_desktop.img
Google Drive:https://drive.google.com/file/d/195JJWvdDGhNdGvmq80rNVXv6kOYwiLHg/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/14YXrCPnsqwF41-8kInAyrA?pwd=md7e (pincode: md7e)
  • Banana Pi new image: Ubuntu 16.04 with Allwinner BSP, use MPV play 1080P video,Allwinner BSP kernel 3.4 , BPI-M2 Ultra/Berry use kernel 3.10
google drive: https://drive.google.com/drive/folders/1DEO7JdMfDhHynC83K7JMxgnNxf1gV82S
Image Links:
HDMI-Version
Image Links:
HDMI-Version
  • 2018-07-09 update
Image Link:
  • 2017-11-13 update
Image Link:
baidu Drive: http://pan.baidu.com/s/1gfvRUk7
Forum thread:http://forum.banana-pi.org/t/bpi-m2-zero-new-image-2017-11-13-ubuntu-16-04-mate-desktop-beta-bpi-m2z-sd-emmc-img/4172
  • LibreElec 10 (Kodi Matrix) at BPI-M2 Zero with Youtube, HBO Max and (probably) Netflix:
http://forum.banana-pi.org/t/libreelec-10-kodi-matrix-at-bpi-m2-zero-with-youtube-hbo-max-and-probably-netflix/12474
Nuevas
  • Nuevas imagenes BPI-M2 Zero
https://forum.banana-pi.org/t/nuevas-imagenes-bpi-m2-zero/13414
