Banana Pi BPI-F2P
[hide]Introduction
Application direction
- Smart Audio
- Smart Payment system
about SunPlus SP7021
characteristics of the SP7021
- Easy-to-use LQFP package.
- Single 3.3V power*.
- 10-year supply guarantee.
- And much more...
- Expansion
- 2 USB header interface
- 40-pin GPIO header compatible
- 7.4V Lithium battery power supply interface
- RTC battery interface
- PoE function support
- Debugging – 3-pin header for UART console, SWD ICE port
- Dimensions – 130x85mm
SDIO interface Wifi&BT
- WiFi&BT board, 802.11 a/b/g/n/ac 2T2R WiFi and Bluectooch 5.0, support BPI-M5 and BPI-F2P
BPI-F2P-SUB baord
we also design a expansion board for BPI-F2P , it support 2 SATA interface and 4G module support interface
Source code on github
- BPI F2S/F2P BPS code with kernel 4.19 and 5.4 source code: https://github.com/BPI-SINOVOIP/BPI-F2S-bsp
- BPI-F2P schematic diagram : https://drive.google.com/file/d/1_S0dL2J3N-xeq6FKy3aPP-3HNdCwqLWt/view?usp=sharing
- BPI-F2P main board DXF file:https://drive.google.com/file/d/1fMyTq3Bp5AHhGHkwwn5JL_vy55Xxbmc9/view?usp=sharing
- BPI-F2P SUB board DXF file: https://drive.google.com/file/d/1URef-K9OI_5OIFStrkbJvGah-3BykDEW/view?usp=sharing
All image download link:
- google drivr:https://drive.google.com/drive/folders/1slYu3CLbP2OIarjarT4hdShBAXbPxDWZ
- baidu cloud:https://pan.baidu.com/s/13l52p--Bb_B3vo-vfBFFqA pincode:L7r1
Ubuntu Linux
- BPI-F2P new image 2021-06-06 update:Ubuntu server 20.04.1 and Ubuntu mate 20.04.1 image,this image support boot from SD card and eMMC flash, this image boot fast than old image
- 2021-06-06-ubuntu-mate-20.04.1-desktop-armhf-ext4-v5.4.35-bpi-f2p.img.zip: Ubuntu Desktop system, Support HDMI interface to display Desktop.
- google link :https://drive.google.com/file/d/1hu5zvw6lbiLUaw5BLRCUFo1HXaDR3ztM/view?usp=drivesdk
- baidu link:https://pan.baidu.com/s/14PXSw4z_UGYWpnxhGbZuFg pincode: s895
- 2021-06-06-ubuntu-server-20.04.1-armhf-ext4-v5.4.35-bpi-f2p.img.zip: Ubuntu Server System, it don’t include Desktop, only support serial console.
- google link : https://drive.google.com/file/d/1f_C_BBM5g6lEVhNpWqIDJaxgivs8gt60/view?usp=drivesdk
- baidu link: https://pan.baidu.com/s/1Uz8L12aS40WZyvmoP5wVhA pincode: nb98
- BPI-F2P new image 2021-01-29 update:Ubuntu server 20.04.1 and Ubuntu mate 20.04.1 image,this image support boot from SD card and eMMC flash
- 2021-01-29-ubuntu-mate-20.04.1-desktop-armhf-ext4-v5.4.35-bpi-f2p.img.zip: Ubuntu Desktop system, Support HDMI interface to display Desktop.
- google link https://drive.google.com/file/d/1eHOMRnR1YWVxIPkBe0vtWvoMJQ9g79J2/view?usp=drivesdk
- 2021-01-29-ubuntu-server-20.04.1-armhf-ext4-v5.4.35-bpi-f2p.img.zip: Ubuntu Server System, it don’t include Desktop, only support serial console.
- google link : https://drive.google.com/file/d/1zHua_PLDInUG1bnplN-3uKZcTgX3AFno/view?usp=drivesdk
- Baidu link:https://pan.baidu.com/s/1JD3Yn9TYRd_nR8A1AJpqdQ Pincode:fv8e
- BPI-F2P new image:Ubuntu server 20.04.1 and Ubuntu mate 20.04.1 image
- BPI-F2P Ubuntu server 20.04.1 image :https://drive.google.com/file/d/1nbHUcwl2Zh1ZKJlZ1223zM8YBr-onKEs/view?usp=drivesdk
- BPI-F2P Ubutntu mate 20.04.1 image:https://drive.google.com/file/d/1HFkckuPsuBploMnntMqPQ3cwqnqY6Y_-/view?usp=drivesdk
- discuss on fourm: http://forum.banana-pi.org/t/bpi-f2p-new-image-ubuntu-server-20-04-1-and-ubuntu-mate-20-04-1-image/11608
- support BPI-F2P-SUB baord . all function test fine
- BPI-F2P new image: Ubuntu mate 18.04.2 2020-08-16
- google driver: https://drive.google.com/file/d/1zVGCs4i8EUAZa4UL_TU0WHko5IXUlsGu/view?usp=drivesdk
- baidu link : https://pan.baidu.com/s/1vsdH_PDQ_oJdP3WBEG43Pg Pincode:3qgs
- discuss on forum: http://forum.banana-pi.org/t/bpi-f2p-new-image-ubuntu-mate-18-04-2-linux-kernel-5-4-2020-08-16/11442
Kail Linux
- password: root/toor
Debian Linux
CentOS linux
- password:root/centos
Fedora-Mate
Mozilla IoT gateway
Yocto Linux
aliexpress : https://www.aliexpress.com/item/4001268419883.html
taobao: https://item.taobao.com/item.htm?ft=t&id=624363638904
