4G module via USB
BPI-4G module extension board with 1 Non-standard micro USB port,you can connect banana pi board with this port ,use 4G function development . also support PIN define ,and connect to BPI-R2. user also can choose 4G module onboard and use the universal 4G module in the market.
Using 4G module with BananaPi
hardware interface
BPI-4G module (4G on board )
BPI-4G module (use USB 4G expansion board ):
BPI-4G module back:
How to use 4G
4G board connect banana pi SBC with USB line ,and connect BPI-R2 with PIN define
BPI 4.0:customization
if you have any 4G customization , we can support you.
4 4G module board via USB interface.
use this module on BPI-R2
