快速上手 香蕉派 BPI-M3
BPI-M3
- 更多BPI-M3 产品资讯 : Banana Pi BPI-M3
- 2 GB LPDDR3 memory
- 8 GB eMMC storage
- WiFi & Bluetooth onboard
Android 系统开发
Load your first image on M3
1.You could download latest image from our forum. Ex: http://wiki.banana-pi.org/Banana_Pi_BPI-M3#Android_5.1.1_V5 2.Put your TF card into a TF-USB adapter, and then plug adapter in your Windows PC usb interface. 3.Prepare your image, and download image burning tools PhoenixCard.exe. 4.Use "PhoenixCard.exe" to burn android image to TF card.![]()
Load your image on M3 EMMC
1.The only different with sd card burning is the image burning mode item choice2.After succeed to burn image to SD, then plug SD card in your M3 3.Press power button, device will copy image to EMMC automatically
How to buld M3 Bsp code
* Prepare a PC which runs ubuntu * Install Docker-ce on your PC,https://docs.docker.com/install/linux/docker-ce/ubuntu/#install-docker-ce * After install Docker, execute "docker pull sinovoip/bpi-build:ubuntu12.04", to pull image * Then you pulled image, execute "docker run --privileged -d -p 2222:22 -v /media:/media sinovoip/bpi-build:ubuntu12.04" * "ssh -p 2222 [email protected] #default passwd is root" * Execute "git clone https://github.com/BPI-SINOVOIP/BPI-M3-bsp.git" on your ubuntu terminal * Execute "./build.sh" to build M3 bsp code * After built, open a new terminal, execute "docker cp xxxxx(your container id):xxxxx(your project path) xxxxx(your pc path)"![]()
Development For Linux
1.You could download latest image from our forum * Here is the example link: http://forum.banana-pi.org/t/banana-pi-bpi-m3-new-image-release-raspbian-jessie-8-0-2018-5-28-v1-1/5847 2.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 4.After step 3, then you can insert your TF card into M3, and press power button setup M3
Update your image
Make your own image
Make one raspbian image
Install Docker
You could try armbian to install docker, here is the image: https://dl.armbian.com/bananapim3/Debian_stretch_dev.7z (Here Thanks for the armbian community)
Download this image to your ubuntu PC (I am using ubuntu PC), then decompress it
- 7z x Debian_stretch_xxx.img
username: root, password: 1234
Here are steps to install docker:
- vim /etc/apt/sources.list
- apt-get update
- apt-get install docker.io
SATA
1. Mount SATA on M3
- "mount /dev/sdx /mnt/xxx"
OTG
1. On M3 console:
2. On PC terminal:
LCD 5" & LCD 7"
- Find "BPI_M3_LCD7.img.gz"
Touch screen
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On M3 console:
- Execute "bluetoothctl"
- Execute these commands:
WiFi on M3
Ov5640
Ov8865
- "/test_ov8865.sh"
IR function
- Execute "getevent"
BPI-Tools
Install Bpi-tools
Update Bpi-tools
- Execute "bpi-tools"
- cd /usr/local/bin
How to Update WiringPi
GPU
- glmark2 Score: 258
File System
