Getting Started with P2-Zero
Overview: BPI-M2Z raspbian
BPI-P2 Zero
Banana Pi BPI-P2 Zero is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Cortex A7 allwinner H2+ processor(Option : H3 and H5), with 512MB RAM memory.8G eMMC flash,100M LAN,add PoE function support , It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
  • CPU: Allwinner H2+, Quad-core Cortex-A7
  • 512MB DDR 3 SDRAM
  • Mini HDMI
  • 40 PIN GPIO, It includes UART, SPI, I2C, IO etc
  • 100M LAN
  • 8G eMMC flash onboard
Load your first Android image on M1
 * Using your USB-Serial Connect debug console on P2 Zero
Install Linux Image on P2 Zero
Install Image to SDcard on Linux PC with bpi-tools
1. Install bpi-tools on your system
   $ apt-get install pv
If you can't access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
2. Insert your SDcard into your PC
   $ bpi-copy xxx.img /dev/sdx
1.Prepare a sd which is installed ubuntu image and bootup with sdcard
2.Copy emmc image to udisk, plug in board, then mount udisk.
3.After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc.
4.After success install, power off the board, eject the sdcard and poweron with emmc boot.
Update your image
1. Get the p2 zero bsp source code
   $ git clone https://github.com/BPI-SINOVOIP/BPI-M2P-bsp-4.4
2. Build the source code according to the README.md, and update the packages to the sdcard with bpi image flashed.
2. Copy Linux image to udisk, plug the udisk to OTG Port(via USB-to-MicroUSB) of the board and mount it.
 $ sudo unzip -p xxx-bpi-p2zero-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
4. Install the linux image in udisk with bpi-tools command
 $ sudo bpi-copy xxx-bpi-p2zero-xxx.img.zip /dev/mmcblk0
How to create an image
  • Boot your SD card with M2 Zero, after M2 Zero finish starting, copy your files and config your system, then poweroff M2 Zero. [If you don't want to config your system, you can skip this step]
  • Execute "bpi-migrate -c bpi-m2z.conf -c ubuntu-mate-from-sd.conf -d /dev/sdx"
OTG
1. On M2 Zero console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M2 Zero and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M2 ZeroP OTG
  • If yes, we could execute "adb shell" to connect M2 Zero by adb now
EMac
  • Use iperf3 to test network
  • Execute "bluetoothctl"
  • Execute these commands:
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
We use HDF5640 camara.
Display
parameters meaning:
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
