Banana Pi BPI-M2 ZERO
As Allwinner H2+ chip is EOL, so BPI-M2 Zero will use H3 chip defaults. but image for H2+ also support H3, so all image is same. support H2+ and H3 chip.
- 512MB DDR 3 SDRAM.
- Mini HDMI.
| CPU | Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core |
| Onboard WIFI | K016/SDIO AP6212(option AP6181、AP6335) | K016/SDIO AP6212(option AP6181、AP6335) | 802.11n wireless, BT 4.1 |
| IR | N/A | N/A | N/A |
| Supported OS | android linux | android linux | Linux |
| Weight | 30g | 15g | 9g |
| 40 PIN GPIO of Banana pi BPI-M2 zero | |||
| CON2-P01 | VCC-3V3 | ||
| CON2-P02 | VCC-5V | ||
| CON2-P04 | VCC-5V | ||
| CON2-P06 | GND | ||
| CON2-P09 | GND | ||
| CON2-P14 | GND | ||
| CON2-P17 | VCC-3V3 | ||
| CON2-P18 | PC4 | PC4 | |
| CON2-P20 | GND | ||
| CON2-P25 | GND | ||
| CON2-P26 | PC7 | PC7 | |
| CON2-P30 | GND | ||
| CON2-P34 | GND | ||
| CON2-P39 | GND | ||
- Update of BPI-WiringPI2 for M2-Zero:https://forum.banana-pi.org/t/update-of-bpi-wiringpi2-for-m2-zero/13554
- code on github:https://github.com/bontango/BPI-WiringPi2
| 24 PIN CSI Camera connector of Banana pi BPI-M2 Zero | |||
| CN3-P01 | NC | ||
| CN3-P02 | GND | ||
| CN3-P04 | CSI0-AVDD | ||
| CN3-P10 | CSI0-DVDD | ||
| CN3-P11 | CSI0-DOVDD | ||
| CN3-P15 | GND | ||
| CN3-P16 | CSI0-D5 | PE9 | |
| CN3-P18 | CSI0-D4 | PE8 | |
| CN3-P19 | CSI0-D0 | PE4 | |
| CN3-P20 | CSI0-D3 | PE7 | |
| CN3-P21 | CSI0-D1 | PE5 | |
| CN3-P22 | CSI0-D2 | PE6 | |
| CN3-P23 | GND | ||
| CN3-P24 | CSI0-DOVDD | ||
| jumper CON3 of Banana pi BPI-M2 Zero | |||
| CON3 P01 | GND | ||
PIN define:
schematic diagram:
test
Zero power with GPIO 5V input
- Allwinner documents:
- Configuracion y uso de GPIO BPI-M2 Zero 1.5.2 : https://forum.banana-pi.org/t/configuracion-y-uso-de-gpio-bpi-m2-zero-1-5-2/15113
- Android 4.4 source code
- Linux source code
- Forum pthread:
Arch Linux
- Armbian_23.05.0-trunk_Bananapim2zero_bullseye_current_6.1.24_mate_desktop.img
- Google Drive:https://drive.google.com/file/d/1Q16Xi6PMSGCW9FxSecIvvf_5rnkqgNsM/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/16vL43zl8zINraHLtnbzlhg?pwd=8888 (pincode: 8888)
- 2022-12-06 Armbian_22.11.0-trunk_Bananapim2zero_bullseye_edge_6.0.9.img.xz
- Google Drive:https://drive.google.com/file/d/11crpUOyLDn49eP76bszXfJiF2D7c0L-8/view?usp=share_link
- Baidu Cloud:https://pan.baidu.com/s/1YLuBICd4mVOoTZzoWaEjCw?pwd=8888 (pincode: 8888)
- Discuss on forum: https://forum.banana-pi.org/t/bananapi-bpi-m2-zero-new-image-release-armbian-bullseye/14448
- Image Link from Armbian official website:
- Forum thread:
RetroPie
retrorangepi
Raspbian
- 2022-09-07 Armbian_22.11.0-trunk_Bananapim2zero_jammy_edge_5.19.6_xfce_desktop.img
- Google Drive:https://drive.google.com/file/d/195JJWvdDGhNdGvmq80rNVXv6kOYwiLHg/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/14YXrCPnsqwF41-8kInAyrA?pwd=md7e (pincode: md7e)
- Image Links:
- HDMI-Version
- Image Links:
- HDMI-Version
- 2018-07-09 update
- Image Link:
- 2017-11-13 update
Nuevas
- Nuevas imagenes BPI-M2 Zero
- SINOVOIP Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M2-Zero/1100417230_40000003593410.html
- Bipai Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M2-Zero/1101951077_40000003414813.html
- Taobao Shop: https://shop108780008.taobao.com/category-1694930631.htm
