香蕉派 BPI-W2
Banana PI BPI-W2是一个高度集成的多媒体网络路由器,可用于高无线性能、家庭娱乐、家庭自动化等…
- Mali T820 MP3 GPU
- 2G DDR4 SDRAM
- 8G eMMC flash
- 2xMIC int/Audio out
- 2 SATA 硬盘接口
- 1 千兆LAN有线网口x 1千兆WAN有线网口
- 1xUSB 3.0接口 2xUSB 2.0接口
- HDMI in & HDMI in
- Mini DP
- TYPE C
开始使用
硬件接示意
电源接口尺寸规格书 :https://drive.google.com/file/d/1k3AWmYOs2XE7lnRxCyytZu0Vpq_Bzcu_/view?usp=sharing
| 香蕉派 BPI-W2 硬件规格表 | |||
| Soc芯片 | Realtek RTD1296 quad-core ARM A53 | ||
| GPU | Mali T820 MP3 GPU | ||
| SDRAM | 2GB DDR4 \(shared with GPU\) | ||
| 供电 | 12V @ 2A via DC power 5.0mmx2.0mm jack | ||
| Low-level peripherals | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | ||
| 有线网口 | 2x 10/100/1000Mbps Ethernet | ||
| Wifi无线/Bluetooth蓝牙 | **Option** ,not support onboard WIFI & BT | ||
| RGMII | 1 RGMII interface with PIN | ||
| 存储 | MicroSD \(TF\) card; 2 native SATA 3 6Gbps ;eMMC;SIM card slot | ||
| 显示 | HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP | ||
| Video decoder/encode | The Video DSP of RTD1296 is dedicated to manipulating,decoding and encoding of video streams in various formats, e.g. decoding 4K2K H.265,Full HD MPEG1/2/4/H.264/H.264 MVC,AVC/VC-1,VP8,AVS,AVS Plus,HD jpeg,etc.Video decoding and encoding can run simultaneously. support 3D de-intrlacing,video scaling up to 4K2K and so on. | ||
| Aideo decoding | Audio decoding is carried out by an Audio DSP that is capable of decoding a set of audio formats,e.g. DTS HD,Dolby Digital Plus,TrueHD,and other popular formats.the Audio DSP also performs audio post processing | ||
| Audio | support two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 2 MIC in | ||
| HDMI 输入/输出 | 1* HDMI 2.0a out port and 1* HDMI 2.0a In port | ||
| Audio outputs/Inputs | HDMI, I2S audio,Audio micro out, Audio out/in with PIN define | ||
| M.2 KEY E:PCIE 2.0/USB 2.0 | 1 pcie 2.0 interface | ||
| M.2 KEY E:PCIe 1.1 / SDIO / USB 2.0 | 1 pcie 1.1 and SDIO interface | ||
| USB 3.0 | 1x USB 3.0 host | ||
| USB 2.0 | 2x USB 2.0 OTG, 1 with standard USB port , 1 define with PIN | ||
| M.2 KEY B | 1 * M.2 interface USB 2.0 for 4G with Micro SIM card slot | ||
| Mini DP | 1* Mini DP | ||
| TYPE C | 1 type C interface | ||
| RTC 实时时钟供电 | RTC battery power interface | ||
| 按键 | Reset button, Power button, U-boot button | ||
| Led灯 | Red, Green, Blue | ||
| 红外 | IR 红外遥控接收 | ||
| 尺寸 | 148 mm × 100.5mm | ||
| 重量 | 100g | ||
GPIO PIN 定义
| 香蕉派 BPI-W2 40-pin GPIO 定义 | |||
| GPIO Pin Name | Default Function | Function 2:GPIO | |
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | 5VD | ||
| CON1-P03 | I2C5\_SCL | GPIO13 | |
| CON1-P04 | 5VD | ||
| CON1-P05 | I2C5\_SDA | GPIO14 | |
| CON1-P06 | GND | ||
| CON1-P07 | PWM0\_0 | IGPIO21 | |
| CON1-P08 | UR2\_TX | IGPIO3 | |
| CON1-P09 | GND | ||
| CON1-P10 | UR2\_RX | IGPIO2 | |
| CON1-P11 | GPIO17 | GPIO17 | |
| CON1-P12 | AO\_BCK | GPIO58 | |
| CON1-P13 | I2C3\_SDA | GPIO25 | |
| CON1-P14 | GND | ||
| CON1-P15 | I2C3\_SCL | GPIO27 | |
| CON1-P16 | UR2\_RTS | IGPIO5 | |
| CON1-P17 | VCC-3V3 | ||
| CON1-P18 | UR2\_CTS | IGPIO4 | |
| CON1-P19 | G\_MOSI | GPIO7 | |
| CON1-P20 | GND | ||
| CON1-P21 | G\_MISO | GPIO4 | |
| CON1-P22 | IR\_TX | IGPIO9 | |
| CON1-P23 | G\_SCK | GPIO5 | |
| CON1-P24 | G\_CS | GPIO6 | |
| CON1-P25 | GND | ||
| CON1-P26 | GPIO8 | GPIO8 | |
| CON1-P27 | I2C4\_SDA | GPIO12 | |
| CON1-P28 | I2C4\_SCL | GPIO11 | |
| CON1-P29 | GPIO100 | GPIO100 | |
| CON1-P30 | GND | ||
| CON1-P31 | AI\_CK | GPIO21 | |
| CON1-P32 | SPDIF | GPIO54 | |
| CON1-P33 | AO\_CK | GPIO59 | |
| CON1-P34 | GND | ||
| CON1-P35 | AO\_LRCK | GPIO57 | |
| CON1-P36 | AI\_BCK | GPIO22 | |
| CON1-P37 | AI\_LRCK | GPIO23 | |
| CON1-P38 | AI\_SDO | GPIO24 | |
| CON1-P39 | GND | ||
| CON1-P40 | AO\_D0 | GPIO60 | |
UART 串口定义
CON 3 是UART接口。对于Banana Pi的开发人员来说,这是获取UART控制台输出以检查系统状态和日志消息的一种简单方法。
| BPI-W2 调试串口 UART(CON3) | |||
| CON2-P1 | GND | ||
| CON2-P2 | UART0-RX | ||
| CON2-P3 | UART0-TX | ||
voltage domain is RGMII.
资源
软件源代码
- HDMI-IN sample code:https://drive.google.com/open?id=17RXX_-mrZh2N6NgyVY6ofKs-NNC48bAM
- BPI-W2 Android 7 source code :https://github.com/BPI-SINOVOIP/BPI-1296-Android7
- BPI-W2 Android 6 source code : https://github.com/BPI-SINOVOIP/BPI-1296-Android6
参考文档
- BPI-W2 硬件原理图 :
- google 下载地址:https://drive.google.com/file/d/1Xn7-nlY0kVJacnRh_EpuS5Fw92_b6qqu/view?usp=sharing
- 百度云下载地址:https://pan.baidu.com/s/1z2FgGpWY4nPGvocx8ymmew pinecode: r5tv
- BPI-W2 DXF 结构文件下载 :https://drive.google.com/file/d/1JDVRxcXdSi8cnX32plBmyrTiKiWDK_ev/view?usp=sharing
- BPI-W2 Realtek 1296 文档下载
- Error creating thumbnail: Unable to save thumbnail to destination
- google drive :https://drive.google.com/file/d/1PLlU5d0INA2U6Er5unEC7-FpnAmkSh7x/view?usp=sharing
- baidu cloud :https://pan.baidu.com/s/1geV5JNl
- SATA-RSM-C052-X22XX 规格
Amazon AWS 认证
Banana Pi BPI-W2 通过 Amazon AWS 认证:https://devices.amazonaws.com/detail/a3G0h000000OvNJEA0/Banana-Pi-BPI-W2
系统镜像
- 2020-05-22 update, Android 7.1, kernel 4.1
- Android Normal Version: Normal android image without hwnat and openwrt.
- Android Router Version: Router mode android image with hwnat and openwrt enabled, ethernet and wifi network must be configured in Openwrt system(Settings->More->Openwrt Settings). The port with bar code label is wan.
- Android ATV version: ATV version android image without hwnat and openwrt. Click the right button on the left side of screen to show the navigation bar If you use mouse for testing.
- How to install Android Image
- 2019-8-16 update This release is for banana pi W2 board, and it is based on Android6.0 & 7.1 Operation system with kernel 4.1
- Android 6.0
- Fetures Map: http://wiki.banana-pi.org/W2_Image_Map#Android_6.0_HDMI
- Google Drive : https://drive.google.com/open?id=1cblHB2rKnDOZmhxbHL79k3QlYfAHOdBe
- Baidu Drive : https://pan.baidu.com/s/1ZdI4Y7B-u7kp8XguGXFkuQ (PinCode:8noz)
- MD5 : 1a90335d798863e31f99c1fae615c43c
- Android 6.0
- Android 7.1
- Fetures Map: http://wiki.banana-pi.org/W2_Image_Map#Android_7.1_HDMI
- Google Drive : https://drive.google.com/open?id=1j1n10Wh9jE7TCDMutwLifPavt_PJ-5x3
- Baidu Drive : https://pan.baidu.com/s/12MkYp0oQ9cUN2N8J3WrHrg (PinCode:2cyy)
- MD5 : 713ddd26e6f2c085c464442e058cf390
- Forum pthread:http://forum.banana-pi.org/t/bpi-w2-new-image-android-6-0-7-1-for-emmc-20190816/9728
- Android 7.1
Android 7.1.1
- Google Drive:
- Forum thread:http://forum.banana-pi.org/t/bpi-w2-new-image-android-7-1-1-v0-1-beta-2018-5-29/5867
Android 6.0.1
- Image Link:
- Forum thread:
- 2019-10-04 update Banana Pi BPI-W2 (RTD1296) new image : Openwrt Lede with Kernel 4.9
- Image Link:
- Forum thread:
- Image Link:
- FAQ
- Debian 10 buster (32bit)
- FAQ
- FAQ
- image Link:
Rasbian
- FAQ
AArch Linux
- Fetures Map:
- AArch64 Linux Lite
- Fetures Map:
- FAQ
- FAQ
OpenSUSE
Kali Linux
RPiTC
- image download:
- SPI ROM Tool:
- SPI ROM Image:
- How-To Update W2 SPI ROM:
