Getting Started with M5/M2Pro
- Mali-G31 MP2 GPU @ 650Mhz
- System Memory – 4GB LPDDR4
- Weight – 48grams
- 3. The SOC rom first boot sequence is emmc, so board can't bootup from SDcard if the emmc is bootable with any image flashed, more info about the image boot sequence please refer to board boot flow.
- 4.
- 2. Download the AML Burn Card Maker tool for create a bootable sdcard to flash android image to emmc, only support windows.
- 3. Download the latest android image.
- 4. Unplug the type-c usb and connect to power supply adaptor to startup.
Install Image with Burn Card Maker Tool
- 1. Open Burn_Card_Maker.exe.
- 2. Insert the SDcard into PC, select the SDcard media from the drop-down list of choose disk, select To Partition and Format if the first time Creating for the card. Clock Open button and choose the android image and Click Make button
- 3. If To Partition and Format selected, the disk format popup,
