Getting Started with M5/M2Pro
Revision as of 21:00, 8 December 2020 by Dangku (talk | contribs) (specifications)
Amlogic S905X3 Processor
  • Mali-G31 MP2 GPU @ 650Mhz
  • System Memory – 4GB LPDDR4
  • Weight – 48grams
Android development
Linux development
