Getting Started with R64
Read more: Banana Pi BPI-R64
- 1G DDR3 SDRAM
- MTK7615 4x4ac wifi on board
- Support 1 SATA interface
- 1 Port USB 3.0
- POE function support
* Prepare 8G/above TF card, USB-Serial interface, Ubuntu System * Using your USB-Serial Connect debug console on R64
Load your first image on R64
1.You could download latest image from our forum * Here is the example image link: 2.Install bpi-tools on your Ubuntu. If you can't access this URL or any other problems, please go to bpi-tools repo and install this tools manually. * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card 4.After step 3, then you can insert your TF card into R64, and press power button to setup R64
Before burning image to eMMC, please prepare a SD card with flashed bootable image and a USB disk. Let's take OpenWrt image (mtk-bpi-r64-preloader-emmc.bin,2020-04-09-OpenWRT-mtk-bpi-r64-EMMC.img) for example, the steps are below:
1. Insert the flashed SD card and power on to start the board.(the image on the SD card can be OpenWrt or other linux OS like ubuntu...)
2. Copy eMMC bootable OpenWrt image(mtk-bpi-r64-preloader-emmc.bin,2020-04-09-OpenWRT-mtk-bpi-r64-EMMC.img) to USB disk, if the image is compressed please uncompress it before copying to USB disk.
3. Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip this step if it is mounted automatically) * mount -t vfat /dev/sda1 /mnt * and change your directory to the mount point, here is : cd /mnt
4. Execute following command to enable and copy image to eMMC: * echo 0 > /sys/block/mmcblk0boot0/force_ro * dd if=2020-04-09-OpenWRT-mtk-bpi-r64-EMMC.img of=/dev/mmcblk0 * dd if=mtk-bpi-r64-preloader-emmc.bin of=/dev/mmcblk0boot0 * mmc bootpart enable 1 1 /dev/mmcblk0
5. Shutdown, remove SD card and USB disk, and restart the board from eMMC.
Network-Configuration
GPIO
40 Pins Definition
PWM Control
SPI touch panel
SPI Panel module:
SPI Panel <–> BPIR64
T_DO, T_DIN, T_CLK <–> SPIC_0: MOSI / MISO / CLK T_CS <–> SPI-CE0 T_IRQ <–> IO-37 SDO, SCK, SDI <–> SPIC_1: MOSI / MISO / CLK LED <–> PIN-31 DC <–> PIN-11 RESET <–> PIN-13 CS <–> SPI-CE1 GND <–> GND-9 VCC <–> 3.3V-1
DTS Modification:
/ { backlight: backlight { compatible = "gpio-backlight"; gpios = <&pio 82 GPIO_ACTIVE_HIGH>; //PIN31 IO-31 : GPIO82 default-on; }; };
&pio { spic0_pins: spic0-pins { mux { function = "spi"; groups = "spic0_0"; }; }; spic1_pins: spic1-pins { mux { function = "spi"; groups = "spic1_0"; }; }; }
&spi0 { pinctrl-names = "default"; pinctrl-0 = <&spic0_pins>; status = "okay"; touch@0 { reg = <0>; //CE0 compatible = "ti,ads7843"; interrupt-parent = <&pio>; interrupts = <86 0>; //PIN37: IO-37 == GPIO86 pendown-gpio = <&pio 86 0>; spi-max-frequency = <1000000>; vcc-supply = <®_3p3v>; wakeup-source; }; };
&spi1 { pinctrl-names = "default"; pinctrl-0 = <&spic1_pins>; status = "okay"; display@0{ compatible = "ilitek,ili9341"; reg = <0>; //CE0 spi-max-frequency = <32000000>; dc-gpios = <&pio 51 GPIO_ACTIVE_HIGH>; //PIN11 UART1-TXD : GPIO51 reset-gpios = <&pio 52 GPIO_ACTIVE_HIGH>; //PIN13 UART1-RXD : GPIO52 backlight = <&backlight>; }; };
Kernel config:
+CONFIG_FB_TFT_ILI9341 +CONFIG_FB_TFT +CONFIG_FB +CONFIG_BACKLIGHT_LCD_SUPPORT +CONFIG_BACKLIGHT_CLASS_DEVICE +CONFIG_BACKLIGHT_GPIO +CONFIG_INPUT +CONFIG_INPUT_TOUCHSCREEN +CONFIG_TOUCHSCREEN_ADS7846
Application:
Package | + Description | Source |
fbv | framebuffer image viewer | https://github.com/godspeed1989/fbv |
input-event-daemon | input-event-daemon with touchTEST event | https://github.com/SAM33/input-event-daemon |
[Global] listen = /dev/input/event0 listen = /dev/input/event1 [TouchTEST] 340,400,3440,1860 = cat /dev/zero > /dev/fb0; fbv -f /root/bpi_608x429.jpg -s 1 340,2260,3440,1860 = cat /dev/zero > /dev/fb0; fbv -f /root/openwrt_449x449.png -s 1
Banana Pi BPI-R64 SPI touch panel test: https://www.youtube.com/watch?v=ikag-D_TI0g&feature=youtu.be
Sata
PCIe
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On R64 console:
BT & BLE on R64
R64 BT Architectural
- BLE on R64
- Input Command "btmw-test", you will enter to "btmw_test_cli" command line
- Here are some example commands:
- MW_GAP name 7622_BT /*rename bt device*/
- MW_GAP info /*check local BT device info*/
- MW_GATTC scan /* start ble scan*/
- MW_GATTC stop_scan /* stop ble scan*/
R64 LAN Function
- Config the ip, "ifconfig eth2 192.168.1.1".
- Start dhcp server, "dhcpd eth2".
- then config iptables and set package forward.
- Add "net.ipv4.ip_forward=1" to "/etc/sysctl.conf"
- "/sbin/sysctl -p" to make forward work
- "iptables -t nat -A POSTROUTING -s 192.168.1.1/24 -o eth3 -j MASQUERADE"
Ap mode on R64
- ra0 is MT7622 2.4G wifi
- rai0 is MT7615 5G wifi
2.4G WiFi
- Use "ifconfig ra0 up" to enable it.
- Config the ip, "ifconfig ra0 192.168.1.1".
- Start dhcp server, "dhcpd ra0".
5G WiFi
- Use "ifconfig rai0 up" to enable it.
- Config the ip, "ifconfig rai0 192.168.1.1".
- Start dhcp server, "dhcpd rai0".
- MT7622 Reference Manual for Develope Board(BPi)
