Getting Started with W2
Read more: Banana Pi BPI-W2
Install Linux Image
Download the latest Linux Images
- Note: Board SW4 switch to 1 for sd boot
Install Image to SD Card with Win32 Disk Imager On Windows
- Install bpi-tools on your linux. If you can't access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
$ apt-get install pv
- After you download the image, insert your TF card into your Linux PC
$ bpi-copy xxx.img /dev/sdx
- After step 2, then you can insert your TF card into W2, and press power button setup W2.
- Prepare a sd with Linux image installed, bootup board from sd card. Copy a Linux image to udisk and plug in W2, mount udisk and use command "bpi-copy xxx-emmc-xxx.img" to flash image to Emmc. After flash successfully, power off the board, eject sdcard and power on again.
Install Android image
Download the latest Android image
Download BPI-W2 USB flash tool
Note:
- 1. BPI-W2 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform.
- 2. Make sure SW4 switch to '0' for emmc boot.
- 3. Read w2_android_usb_download_tool/document/bananapi_w2_usb_download_tool_guide.doc before flashing image.
GPIO
PWM Control
SATA
1. Mount dev on W2
- "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
- iperf3 -c [server]
- iperf3 -u -c [server]
- iperf3 -s
WiFi & BT
STA
network={
ssid="ssid"
psk="password"
priority=1
AP
Developing
Develop 4G module with W2
GPU
- glmark2 Score: 30
