Getting Started with M2 Zero
Overview Banana Pi BPI-M2 ZERO
Overview: BPI-M2Z raspbian
Android 4.4
Ubuntu Linux
BPI-M2 Zero
  • 512MB SDRAM.
  • Mini HDMI.
Install Linux Image on M2 Zero
Install Image to SDcard on Linux PC with bpi-tools
1. Install bpi-tools on your system
   $ apt-get install pv
If you can't access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
2. Insert your SDcard into your PC
   $ bpi-copy xxx.img /dev/sdx
1.Prepare a sd which is installed ubuntu image and bootup with sdcard
2.Copy emmc image to udisk, plug in board, then mount udisk.
3.After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc.
4.After success install, power off the board, eject the sdcard and poweron with emmc boot.
Update your image
1. Get the m2 zero bsp source code
   $ git clone https://github.com/BPI-SINOVOIP/BPI-M2P-bsp-4.4
2. Build the source code according to the README.md, and update the packages to the sdcard with bpi image flashed.
How to create an image
  • Boot your SD card with M2 Zero, after M2 Zero finish starting, copy your files and config your system, then poweroff M2 Zero. [If you don't want to config your system, you can skip this step]
  • Execute "bpi-migrate -c bpi-m2z.conf -c ubuntu-mate-from-sd.conf -d /dev/sdx"
OTG
1. On M2 Zero console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M2 Zero and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M2 ZeroP OTG
  • If yes, we could execute "adb shell" to connect M2 Zero by adb now
USB Ethernet
  • Prepare a USB to OTG wire, usb ethernet adapter
  • Use iperf3 to test network
  • Execute "bluetoothctl"
  • Execute these commands:
  • ip link set wlan0 up
network={
ssid="ssid"
psk="password"
priority=1
  • dhclient wlan0
We use HDF5640 camara.
Display
parameters meaning:
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
