Getting Started with P2-Zero
- Read more about : Banana Pi BPI-P2 Zero
BPI-P2 Zero
- CPU: Allwinner H2+, Quad-core Cortex-A7
- 512MB DDR 3 SDRAM
- Mini HDMI
- 40 PIN GPIO, It includes UART, SPI, I2C, IO etc
- 100M LAN
- 8G eMMC flash onboard
* Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System * Using your USB-Serial Connect debug console on P2 Zero
Install Linux Image on P2 Zero
Install Image to SDcard on Linux PC with bpi-tools
- 1. Install bpi-tools on your system
- 2. Insert your SDcard into your PC
$ bpi-copy xxx.img /dev/sdx
- 4.After success install, power off the board, eject the sdcard and poweron with emmc boot.
Update your image
- 1. Get the p2 zero bsp source code
$ git clone https://github.com/BPI-SINOVOIP/BPI-M2P-bsp-4.4
- 2. Build the source code according to the README.md, and update the packages to the sdcard with bpi image flashed.
How to create an image
OTG
1. On M2 Zero console:
2. On PC terminal:
EMac
- Use iperf3 to test network
- Execute "bluetoothctl"
- Execute these commands:
We use HDF5640 camara.
Display
parameters meaning:
BPI-Tools
Install Bpi-tools
Update Bpi-tools
- Execute "bpi-tools"
- cd /usr/local/bin
How to Update WiringPi
