Getting Started with M64
Revision as of 09:50, 10 July 2020 by Dangku (talk | contribs) (Prepare)
Overview Banana Pi BPI-M64
Overview: BPI-M64 respbian linux
A64 Key Features
  • 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-A64
  • 2GB DDR3 SDRAM
  • 8G EMMC
  • 10/100/1000Mbps Ethernet
  • WiFi (AP6212) & Bluetooth
R18 Key Features
  • 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-R18
  • 2GB DDR3 SDRAM
  • 8G EMMC
Development For Android
Install Android Image
1. Prepare USB-Serial cable, PC with Linux or WIndows 7/10
2. A USB-Serial cable for console debug.
3. M64 board is only suport DC power supply bootup.
4. If you want insert a SDcard for Android storage using, and your SDcard was download Linux Image or any other allwinner bootable SDcard image, please format the SDcard start from block0.
5. Download and Install Allwinner Image Download Tools, PhoenixSuit is for window and LiveSuit is for Linux
6. Download BPI latest Android Image
Install Image with PhoenixSuit on Windows
1. Open PhoenixSuit, click the Firmware icon to switching to firmware download panel, then click Image button and choose the Android Image file.
2. M64 board disconnect DC power, press and hold the uboot-key button(new uart debug pin), plugin mirco-usb cable to PC, popup a warning dialog.
3 Press Yes to continue and popup another waring dialog, Press Yes to continue
4 Downloading
5 Download finish
Install Image with LiveSuit
According to the Readme.pdf in LiveSuit Install package, After install the LiveSuit successfully please run LiveSuit.sh with root permission, then the download process is almost the same as PhoenixSuit.
Build Android source code
Get Android source code
Android 7.0
 $ git clone https://github.com/BPI-SINOVOIP/BPI-A64-Android7
Android 6.1
Build Android Source code
Development For Linux
Install Linux Image
1. Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
2. Using your USB-Serial Connect debug console on M64
3. Install bpi-tools on your Linux PC
  $ apt-get install pv
4. Download BPI latest image
Install Image to SDcard
1. Install image with bpi-tools on Linux
plug your sd card to your Linux PC, and run
  $ sudo bpi-copy  xxx.img /dev/sdX
2. Install bpi image with Etcher on Windows, Linux and MacOS
Install Image to EMMC
1. Prepare a sd which is installed Linux image and bootup with sdcard
2. Copy emmc image to udisk then plug in M64, then mount udisk.
3. After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc.
4. After success install, power off M64, eject the sdcard and poweron with emmc boot.
Switch to LCD7 bootup
  • The default release images are HDMI bootup type, you can switch to LCD bootup type after first boot.
 $ sudo bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/BPI-M64-LCD7-linux4.4-8k.img.gz
 $ reboot
Build Linux source code
Get the bsp source code
 $ git clone https://github.com/BPI-SINOVOIP/BPI-M64-bsp-4.4.git
Build the bsp source code
Other development and test
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M2U console:
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on A64
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
Ap Mode
interface=wlan0
driver=nl80211
ssid=test
hw_mode=g
channel=1
  • nmcli radio wifi off
  • rfkill unblock 1
  • rfkill unblock 2
  • ifconfig wlan0 up
  • hostapd -d hostapd.conf
  • To access a GPIO pin you first need to export it with
  • with XX being the number of the desired pin. To obtain the correct number you have to calculate it from the pin name (like PH18)
 (position of letter in alphabet - 1) * 32 + pin number
  for PH18 this would be ( 8 - 1) * 32 + 18 = 224 + 18 = 242 (since 'h' is the 8th letter)
  • echo "out/in" > /sys/class/gpio/gpio*NUMBER*/direction
  • echo "0/1" > /sys/class/gpio/gpio*NUMBER*/value
We use HDF5640 camara.
IR function
  • Execute "getevent"
  • Use your IR device to send information to A64
  • cd /usr/local/bin
WringPi
How to Update WiringPi
  • If your image is 32bit please do this command to install wring pi
  • If your image is 64bit please do:"bpi-update -c bpi-pkg-bpi-wiringpi-arm64.conf"
File System
