Getting Started with M64
[hide]- 1 Introduction
- 2 Development For Android
- 3 Development For Linux
- Read more about : Banana Pi BPI-M64
A64 Key Features
- 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-A64
- 2GB DDR3 SDRAM
- 8G EMMC
- 10/100/1000Mbps Ethernet
- WiFi (AP6212) & Bluetooth
R18 Key Features
- 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-R18
- 2GB DDR3 SDRAM
- 8G EMMC
Install Android Image on M64
Build M64 Android source code
Install Linux Image
- 1. Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
- 2. Using your USB-Serial Connect debug console on M64
- 3. Install bpi-tools on your Linux PC
- 4. Download BPI latest image
Install Image to SDcard
- 1. Install image with bpi-tools on Linux
- plug your sd card to your Linux PC, and run
$ sudo bpi-copy xxx.img /dev/sdX
- 2. Install bpi image with Etcher on Windows, Linux and MacOS
Install Image to EMMC
- 1. Prepare a sd which is installed Linux image and bootup with sdcard
- 2. Copy emmc image to udisk then plug in M64, then mount udisk.
- 3. After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc.
- 4. After success install, power off M64, eject the sdcard and poweron with emmc boot.
Switch to LCD7 bootup
- The default release images are HDMI bootup type, you can switch to LCD bootup type after first boot.
$ sudo bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/BPI-M64-LCD7-linux4.4-8k.img.gz $ reboot
Build M64 Linux source code
Other development and test
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On M2U console:
- Execute "bluetoothctl"
- Execute these commands:
WiFi on A64
Ap Mode
interface=wlan0 driver=nl80211 ssid=test hw_mode=g channel=1
- nmcli radio wifi off
- rfkill unblock 1
- rfkill unblock 2
- ifconfig wlan0 up
- hostapd -d hostapd.conf
We use HDF5640 camara.
IR function
- Execute "getevent"
- Use your IR device to send information to A64
- cd /usr/local/bin
WringPi
How to Update WiringPi
- If your image is 32bit please do this command to install wring pi
- If your image is 64bit please do:"bpi-update -c bpi-pkg-bpi-wiringpi-arm64.conf"
File System
