Getting Started with M64
- 1 Introduction
- 2 Development For Linux
- 2.1 Basic Development
- 2.2 Advanced Development
- 2.3 FAQ
BPI-M64
Overview Banana Pi BPI-M64
- Read more about : Banana Pi BPI-M64
A64 Key Features
- 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-A64
- 2GB DDR3 SDRAM
- 8G EMMC
- 10/100/1000Mbps Ethernet
- WiFi (AP6212) & Bluetooth
R18 Key Features
- 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-R18
- 2GB DDR3 SDRAM
- 8G EMMC
* Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System * Using your USB-Serial Connect debug console on M64
Load your first image on M64
1.You could download latest image from our forum 2.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 4.After step 3, then you can insert your TF card into M64, and press power button setup M64
Load your first image on M64 EMMC
* Run your M64 with TF card * Copy "xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to your USB disk * Plug your USB disk in M2U * After M64 recognise USB disk, execute "bpi-copy xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to install image on EMMC * Then power off M64, take TF card out, power on M64
Update your image
* After built bsp code, you could find "SD" directory in project, "cd SD" you could find the generated bootloader, rootfs * execute “bpi-tools”, to update your bpi tools; * execute “bpi-update -c bpi-m64.conf -d /dev/sdX”, to download new driver to update your image * execute “file *.tgz”, to check download files’ type is compressed data * execute “bpi-bootsel”, you will see the bootloader path, “/usr/lib/u-boot/bananapi/bpi-m64/u-boot-with-dtb-bpi-m64-720P-8k.img.gz” * execute “bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/u-boot-with-dtb-bpi-m64-720P-8k.img.gz”, to update your bootloader * reboot
How to build uboot & kernel
Install tools
- apt-get udpate
- apt-get install pv
Touch screen
LCD 7"
- Find "BPI_A64_LCD7.img.gz"
- Then execute "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/u-boot-with-dtb-bpi-m64-lcd7-8k.img.gz"
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On M2U console:
- Execute "bluetoothctl"
- Execute these commands:
WiFi on A64
network={
ssid="ssid"
psk="password"
priority=1
Ap Mode
interface=wlan0 driver=nl80211 ssid=test hw_mode=g channel=1
- nmcli radio wifi off
- rfkill unblock 1
- rfkill unblock 2
- ifconfig wlan0 up
- hostapd -d hostapd.conf
We use HDF5640 camara.
IR function
- Execute "getevent"
- Use your IR device to send information to A64
- cd /usr/local/bin
WringPi
How to Update WiringPi
- If your image is 32bit please do this command to install wring pi
- If your image is 64bit please do:"bpi-update -c bpi-pkg-bpi-wiringpi-arm64.conf"
File System
