Getting Started with M2M
Revision as of 21:18, 25 May 2020 by Dangku (talk | contribs) (Prepare)
BPI-M2M
  • 512MB DDR3 SDRAM
Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System, connect USB-Serial Connect debug console to M2M debug uart.
Install bpi-tools
 $ apt-get install pv
Install bpi image to SD card
1. Download image
2. Install image with bpi-tools on Linux
plug your sd card to your Linux PC
       $ bpi-copy  xxx.img /dev/sdX
3. Install bpi image with Etcher on Windows, Linux and MacOS
1. Prepare a sd which is installed ubuntu image and bootup with sdcard
2. Copy emmc image to udisk then plug in W2, then mount udisk.
3. After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc.
4. After success install, power off M4, eject the sdcard and poweron with emmc boot.
Build & Install
Get the bsp source code
 $ git clone https://github.com/BPI-SINOVOIP/BPI-M2M-bsp.git
Build the bsp source code
 $ ./build.sh 1
Get the docker image from Sinovoip Dock Hub, build the source code with this docker image if you have build environment issue.
Install the bsp package to SD card with bpi image flashed
 $ sudo ./update_bsp2sd.sh /dev/sdX
Advance Development
  • Execute "bluetoothctl"
  • Execute these commands:
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
StartX
  • apt-get install xorg
  • apt-get install xserver-xorg
  • apt-get install xinit
https://askubuntu.com/questions/518454/what-does-startx-command-do
NAS Application
1. Usb hub + sata to usb
  • HDD is supported
  • SSD is supported
We use HDF5640 camara.
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
