Getting Started with W2
Revision as of 02:55, 22 May 2020 by Dangku (talk | contribs) (Install Android image)
Overview: BPI-W2 Android 6.0
Read more: Banana Pi BPI-W2
  • Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
  • Using your USB-Serial Connect debug console on W2
Install Linux Image
Download the latest Linux Images
Note: Board SW4 switch to 1 for sd boot
Install Image to SD Card with Win32 Disk Imager On Windows
How to Format SD card on Windows
How to Install Image On SD Card with Win32 Disk Imager
Install bpi-tools on your linux
    $ apt-get install pv
After you download the image, insert your TF card into your Linux PC
    $ bpi-copy xxx.img /dev/sdx
After step 2, then you can insert your TF card into W2, and press power button setup W2.
Prepare a sd with Linux image installed, bootup board from sd card. Copy a Linux image to udisk and plug in W2, mount udisk and use command "bpi-copy xxx-emmc-xxx.img" to flash image to Emmc. After flash successfully, power off the board, eject sdcard and power on again.
Download the latest android image
Download BPI-W2 USB flash tool
Note:
1. BPI-W2 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform.
2. Make sure SW4 switch to '0' for emmc boot.
3. Read document/bananapi_w2_usb_download_tool_guide.doc before flashing image.
How to support your IR Remote
GPIO
PWM Control
SATA
1. Mount dev on W2
  • "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
  • iperf3 -c [server]
  • iperf3 -u -c [server]
  • iperf3 -s
WiFi & BT
STA
  • ip link set wlan0 up
network={
ssid="ssid"
psk="password"
priority=1
  • dhclient wlan0
AP
Developing
Develop 4G module with W2
GPU
  • Execute "glmark2-es" to start OpenGL test
  • glmark2 Score: 30
Make your own image
