Getting Started with W2
Overview Banana Pi BPI-W2
Overview: BPI-W2 Android 6.0
Debian 9 Linux Image Release 2018-09-18
BananaPI-W2 Ubuntu 18.04 New Image Release 2018-09-17
BananaPI-W2 Raspbian 9.4 New Image Release 2018-09-17
RPiTCv3_1.12-demo-bpi-w2-beta-2018-09-03
Read more: Banana Pi BPI-W2
  • Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
  • Using your USB-Serial Connect debug console on W2
Install Linux Image
Download the latest Linux Images
Note: Board SW4 switch to 1 for sd boot
Install Image to SD Card with Win32 Disk Imager On Windows
How to Format SD card on Windows
How to Install Image On SD Card with Win32 Disk Imager
Install Image to SD Card On Ubuntu with Bpi-tools
Install bpi-tools on your system
    $ apt-get install pv
After you download the image, insert your TF card into your Ubuntu
    $ bpi-copy xxx.img /dev/sdx
After step 2, then you can insert your TF card into W2, and press power button setup W2.
Install Image to SD Card with Etcher
Prepare a sd with Linux image installed, bootup board from sd card. Copy a Linux image to udisk and plug in W2, mount udisk and use command "bpi-copy xxx-emmc-xxx.img" to flash image to Emmc. After flash successfully, power off the board, eject sdcard and power on again.
Install Android image
Download the latest android image
Download BPI-W2 USB flash tool
Note:
1. BPI-W2 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform.
2. Make sure SW4 switch to '0' for emmc boot.
3. Read document/bananapi_w2_usb_download_tool_guide.doc before flashing image.
GPIO
PWM Control
SATA
1. Mount dev on W2
  • "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
  • iperf3 -c [server]
  • iperf3 -u -c [server]
  • iperf3 -s
WiFi & BT
STA
  • ip link set wlan0 up
network={
ssid="ssid"
psk="password"
priority=1
  • dhclient wlan0
AP
Developing
Develop 4G module with W2
GPU
  • Execute "glmark2-es" to start OpenGL test
  • glmark2 Score: 30
Make your own image
