Getting Started with W2
Read more: Banana Pi BPI-W2
Install Linux Image
Install Image to SD Card On Windows
- Board SW4 switch to 1
- English:
1.Format SD card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#Format_your_SD_under_Windows_os
2.Install Image On SD Card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#how_to_write_Linux_image
- Chinese:
https://www.cnblogs.com/topbin/p/10882992.html
Install Image to SD Card On Ubuntu with Bpi-tools
1.Install bpi-tools on your system $ apt-get install pv $ curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 2.After you download the image, insert your TF card into your Ubuntu $ bpi-copy xxx.img /dev/sdx 3.After step 2, then you can insert your TF card into W2, and press power button setup W2.
Install Image to SD Card with Etcher
1.Prepare a sd which is installed ubuntu image, the Board SW4 switch to 1, let W2 boot from sd card. 2.Copy emmc image to udisk then plug in W2, then mount udisk. 3.After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc. 4.After success to install, power off W2, switch SW4 to 0, power on W2.
Install Android image
Download the latest android image
Download BPI-W2 USB flash tool
Note:
- 1. BPI-W2 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform.
- 2. Make sure SW4 switch to '0' for emmc boot.
- 3. Read document/bananapi_w2_usb_download_tool_guide.doc before flashing image.
GPIO
PWM Control
SATA
1. Mount dev on W2
- "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
- iperf3 -c [server]
- iperf3 -u -c [server]
- iperf3 -s
WiFi & BT
STA
AP
Developing
Develop 4G module with W2
GPU
- glmark2 Score: 30
