Getting Started with M4
BPI-M4
![](/images/thumb/a/ac/Banana_Pi_BPI-M4_1.jpg/300x210x300px-Banana_Pi_BPI-M4_1.jpg.pagespeed.ic.RQ6XEjUD01.jpg)
Overview Banana Pi BPI-M4
- Read more about : Banana Pi BPI-M4
- 8G eMMC flash (max 64 GB)
- USB 2.0 TYPE C
- PoE function support
Development For Android
Install Android Image
Download the latest android image and BPI-M4 USB flash tool
Note:
1. BPI-M4 Android8 image only support 2GB ddr board. 2. BPI-M4 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform. 3. Make sure SW2 (board bottom near sd slot) switch to '1' for emmc boot. 4. Read document/bananapi_m4_usb_download_tool_guide.doc before flashing image.
Development For Linux
Install Linux Image On M4
Download the latest Linux image
- Note:
- 1. Board SW2 switch to 0 for sd boot
- 2. For the compatibility of new 2GB and 1GB board with one Linux image, the old batch (before May, 2020) 1GB board must update the spirom firmware, so it can run the new release image.
- 1.Install bpi-tools on your linux
- 2.Insert your TF card into your PC
$ bpi-copy xxx.img /dev/sdx
- 2.Copy emmc image to udisk then plug in W2, then mount udisk.
- 4.After success install, power off M4, eject the sdcard and poweron with emmc boot.
Installed Docker
EMAC
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On M3 console:
You have two ways to setup BT
1. Use commands to setup BT
- Execute "bluetoothctl"
- Execute these commands:
2. Use UI interface to setup BT
WiFi on M4
