Getting Started with M4
BPI-M4
Overview Banana Pi BPI-M4
Overview:Realtek RTD1395
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
Development For Android
Install Android Image
Download the latest android image and BPI-M4 USB flash tool
Note:
 1. BPI-M4 Android8 image only support 2GB ddr board.
 2. BPI-M4 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform.
 3. Make sure SW2 (board bottom near sd slot) switch to '1' for emmc boot.
 4. Read document/bananapi_m4_usb_download_tool_guide.doc before flashing image.
Development For Linux
Install Linux Image On M4
Download the latest Linux image
Note: Board SW2 switch to 0 for sd boot
Install Image to SD Card On Ubuntu with Bpi-tools
1.Install bpi-tools on your system
    $ apt-get install pv
2.After you download the image, insert your TF card into your Ubuntu
    $ bpi-copy xxx.img /dev/sdx
Install Image to SD Card with Etcher
1.Prepare a sd which is installed ubuntu image and bootup with sdcard
2.Copy emmc image to udisk then plug in W2, then mount udisk.
3.After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc.
4.After success to install, power off M4, eject the sdcard and poweron with emmc boot.
Installed Docker
EMAC
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M3 console:
You have two ways to setup BT
1. Use commands to setup BT
  • Execute "bluetoothctl"
  • Execute these commands:
2. Use UI interface to setup BT
WiFi on M4
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
