Getting Started with W2
Overview Banana Pi BPI-W2
Read more: Banana Pi BPI-W2
Install Linux Image On W2
Install Image to SD Card On Windows
- Board SW4 switch to 1
- English:
1.Format SD card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#Format_your_SD_under_Windows_os
2.Install Image On SD Card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#how_to_write_Linux_image
- Chinese:
https://www.cnblogs.com/topbin/p/10882992.html
Install Image to SD Card On Ubuntu
1.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 2.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 3.After step 2, then you can insert your TF card into W2, and press power button setup W2.
1.Prepare a sd which is installed ubuntu image, the Board SW4 switch to 1, let W2 boot from sd card. 2.Copy emmc image to udisk then plug in W2, then mount udisk. 3.After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc. 4.After success to install, power off W2, switch SW4 to 0, power on W2.
Install Android image on W2
GPIO
PWM Control
SATA
1. Mount dev on W2
- "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
- iperf3 -c [server]
- iperf3 -u -c [server]
- iperf3 -s
WiFi & BT
STA
network={
ssid="ssid"
psk="password"
priority=1
AP
Developing
Develop 4G module with W2
GPU
- glmark2 Score: 30
