Getting Started with M4
BPI-M4
- Read more about : Banana Pi BPI-M4
- 8G eMMC flash (max 64 GB)
- USB 2.0 TYPE C
- PoE function support
Development For Android
Install Android
Download the latest android image and BPI-M4 USB flash tool
Note:
1. BPI-M4 Android8 image only support 2GB ddr board. 2. BPI-M4 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform. 3. Make sure SW2 (board bottom near sd slot) switch to '1' for emmc boot. 4. Read document/bananapi_m4_usb_download_tool_guide.doc before flashing image.
Development For Linux
Installed Docker
EMAC
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On M3 console:
You have two ways to setup BT
1. Use commands to setup BT
- Execute "bluetoothctl"
- Execute these commands:
2. Use UI interface to setup BT
WiFi on M4
