香蕉派 BPI-M2 ZERO
Revision as of 22:38, 5 May 2020 by Sinovoip (talk | contribs) (Image Release)
  • 512MB DDR 3 SDRAM.
  • Mini HDMI.
Hardware interfaces
IR N/A N/A N/A
Weight 30g 15g 9g
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI0-SDA PA12-EINT12
CON2-P04 VCC-5V
CON2-P05 TWI0-SCK PA11-EINT11
CON2-P06 GND
CON2-P07 PWM1 PA6-EINT6
CON2-P09 GND
CON2-P11 UART2-RX PA1-EINT1
CON2-P13 UART2-TX PA0-EINT0
CON2-P14 GND
CON2-P15 UART2-CTS PA3-EINT3
CON2-P17 VCC-3V3
CON2-P18 PC4 PC4
CON2-P19 SPI0-MOSI PC0
CON2-P20 GND
CON2-P21 SPI0-MISO PC1
CON2-P22 UART2-RTS PA2-EINT2
CON2-P23 SPI0-CLK PC2
CON2-P24 SPI0-CS PC3
CON2-P25 GND
CON2-P26 PC7 PC7
CON2-P27 TWI1-SDA PA19-EINT19
CON2-P28 TWI1-SCK PA18-EINT18
CON2-P29 PA7-EINT7 PA7-EINT7
CON2-P30 GND
CON2-P31 PA8-EINT8 PA8-EINT8
CON2-P33 PA9-EINT9 PA9-EINT9
CON2-P34 GND
CON2-P39 GND
CN3-P01 NC
CN3-P02 GND
CN3-P03 CSI0-SDA PE13
CN3-P04 CSI0-AVDD
CN3-P05 CSI0-SCK PE12
CN3-P06 CSI0-Reset PE14
CN3-P07 CSI0-VSYNC PE3
CN3-P08 CSI0-PWDN PE15
CN3-P09 CSI0-HSYNC PE2
CN3-P10 CSI0-DVDD
CN3-P11 CSI0-DOVDD
CN3-P12 CSI0-D7 PE11
CN3-P13 CSI0-MCLK PE1
CN3-P14 CSI0-D6 PE10
CN3-P15 GND
CN3-P16 CSI0-D5 PE9
CN3-P17 CSI0-PCLK PE0
CN3-P18 CSI0-D4 PE8
CN3-P19 CSI0-D0 PE4
CN3-P20 CSI0-D3 PE7
CN3-P21 CSI0-D1 PE5
CN3-P22 CSI0-D2 PE6
CN3-P23 GND
CN3-P24 CSI0-DOVDD
CON3 P03 UART0-TXD PA4
CON3 P02 UART0-RXD PA5
CON3 P01 GND
PIN define:
schematic diagram:
test
Zero power with GPIO 5V input
  • Android 4.4 source code
  • Linux source code
  • Banana Pi BPI-M2 Zero new image: 2020-04-28 Debian Rasbian Ubuntu
2020-04-28-debian-9-stretch-lite-bpi-m2z-sd-emmc.img.zip
2020-04-28-raspbian-stretch-bpi-m2z-sd-emmc.img.zip
2020-04-28-ubuntu-16.04-mate-desktop-bpi-m2z-sd-emmc.img.zip
2020-04-28-ubuntu-16.04-server-bpi-m2z-sd-emmc.img.zip
Android 4.4
2018-07-09 update Android 4.4
Forum pthread:
2017-11-12 update Android 4.4
Forum pthread:
RetroPie
retrorangepi
Raspbian
raspbian-jessie-ap6212-bpi-m2z-sd-emmc image
  • raspbian-jessie-ap6212-bpi-m2z-sd-emmc image 2020-04-10,fixed wifi&bt issue
discuss on fourm: http://forum.banana-pi.org/t/banana-pi-bpi-m2-zero-new-image-2020-04-10-raspbian-jessie-ap6212-bpi-m2z-sd-emmc-image/10978
M2Z & P2Zero Raspbian 9.4
HDMI-Version
Md5sum : 25aca018ee40a6df903e1f51b9d73327
2018-07-09
Ubuntu 16.04 mate desktop
2018-07-09
2017-11-13
