BPI-EAI80 AIoT board
Revision as of 02:41, 22 April 2020 by Sinovoip (talk | contribs) (Introduction BPI-EAI80)
BPI-AI Kendryte K210 RISC-V
BPI-Bit with ESP32 design
BPI-EAI80 AIoT board use Edgeless EAI80 chip design .it have Dual-Cortex M4F@200MHz 500DMIPS and AI-NPU:CNN-NPU @300 MHz 300GOPS. support LVDS pannel and camera interface. onboard wifi
Hardware Spec
  • CPU Dual-Cortex M4F@200MHz 500DMIPS
  • AI-NPU:CNN-NPU @300 MHz 300GOPS
  • 2D Graph :Dual-Camera Max
  • SDRAM 8M
  • LCD 1024*768 TFT-LCD
  • CANBUS 2.0 A/B
  • ESP8266 Wifi onboard
  • 40PIN GPIO (share with LCD )
  • 2 Mic support
  • Size: 86x54mm
About Edgeless EAI series
EAI chip Device Summary
EAI series Documents
