BPI-EAI80 AIoT board
Introduction BPI-EAI80
BPI-AI Kendryte K210 RISC-V
BPI-Bit with ESP32 design
BPI-K210 RISC-V AIoT board
BPI-EAI80 board use Edgeless EAI80 chip design .
About Edgeless EAI series
EAI chip Device Summary
EAI series Documents
