BPI-EAI80 AIoT board
Revision as of 19:41, 17 April 2020 by Sinovoip (talk | contribs) (Created page with "= Introduction= thumb|BPI-EAI80 AI board Gree EAI80 chip design thumb|[[BPI-EAI80 AI board Gree EAI80 chi...")
BPI-AI Kendryte K210 RISC-V
BPI-Bit with ESP32 design
BPI-EAI80 board use Edgeless EAI80 chip design .
About Edgeless EAI series
EAI chip Device Summary
