10.1 HDMI touch panel
Banana Pi BPI-M1 Allwinner A20
BPI 10.1 HDMI touch panel
this module have HDMI interface on baord ,so it support BPI-M1,BPI-M1+,BPI-M2,BPI-M3,BPI-M64,BPI-M2U,BPI-M2B BPI-R1.
LCD module for Banana Pi board via an conversion board to connect to the LCD connector designed specifically for interfacing to LCD.
Banana pi LCD Connector :The LCD Connector is a stander Type-A HDMI connector which can connect to HDMI-TX.
it support two touch panel
1024*600 touch panel
| HardWare Specification of 10.1 HDMI panel | |||
| TFT LCD MODULE | HC101TK20050 | ||
| TP MODULE | GT9271 | ||
| Panel Size Size | 10.1 inches | ||
| Resolution | 1024 (RGB) x 600 | ||
| Display Interface | HDMI | ||
| TP Interface | USB | ||
| Color Depth | 16.7M | ||
| Viewing Direction | 6 o’clock | ||
| Active Area(mm) | 222.72(H)x125.28(V) | ||
| OutlineDimension(mm) | 235(W)×143(H)×5.0( D) | ||
| Display Format | RGB vertical stripe | ||
| Display Mode | Normally White | ||
| Operation Temperature | -20~70℃ | ||
| Weight (g) | TBD | ||
1280*800 touch panel
| TFT LCD MODULE | HC101I35025NB | ||
| TP MODULE | ILI2511 | ||
| Resolution | 1280 (RGB) x 800 | ||
| TP Interface | USB-HID | ||
| Active Area(mm) | 216.96(W) × 135.60(H) | ||
| OutlineDimension(mm) | 229.46(W) ×149.1(H) ×2.50(D) | ||
back:
BPI 10.1 touch panel support HDMI interface
cable line
How to use
we have finished all Banana pi boards driver , it support Android,Linux and windows.
banana pi BPI-10 1 HDMI touch screen demo with Linux:https://www.youtube.com/watch?v=R4OKR4vj1Ow&feature=youtu.be
