10.1 HDMI touch panel
BPI 10.1 HDMI touch panel
this module have HDMI interface on baord ,so it support BPI-M1,BPI-M1+,BPI-M2,BPI-M3,BPI-M64,BPI-M2U,BPI-M2B BPI-R1.
LCD module for Banana Pi board via an conversion board to connect to the LCD connector designed specifically for interfacing to LCD.
it support two touch panel
1024*600 touch panel
HardWare Specification of 10.1 HDMI panel | |||
TFT LCD MODULE | HC101TK20050 | ||
TP MODULE | GT9271 | ||
Panel Size Size | 10.1 inches | ||
Resolution | 1024 (RGB) x 600 | ||
Display Interface | HDMI | ||
TP Interface | USB | ||
Color Depth | 16.7M | ||
Viewing Direction | 6 o’clock | ||
Active Area(mm) | 222.72(H)x125.28(V) | ||
OutlineDimension(mm) | 235(W)×143(H)×5.0( D) | ||
Display Format | RGB vertical stripe | ||
Display Mode | Normally White | ||
Operation Temperature | -20~70℃ | ||
Weight (g) | TBD |
1280*800 touch panel
TFT LCD MODULE | HC101I35025NB | ||
TP MODULE | ILI2511 | ||
Resolution | 1280 (RGB) x 800 | ||
TP Interface | USB-HID | ||
Active Area(mm) | 216.96(W) × 135.60(H) | ||
OutlineDimension(mm) | 229.46(W) ×149.1(H) ×2.50(D) | ||
Weight (g) | TBD |
back:
BPI 10.1 touch panel support HDMI interface
cable line
How to use
we have finished all Banana pi boards driver , it support Android,Linux and windows.
banana pi BPI-10 1 HDMI touch screen demo with Linux:https://www.youtube.com/watch?v=R4OKR4vj1Ow&feature=youtu.be
