Banana Pi BPI-R64
Revision as of 16:25, 12 April 2020 by Sinovoip (talk | contribs) (BPI-MT7615 802.11 ac wifi 4x4 dual-band)
Banana Pi BPI-R64 with MT7622
Overview:banana Pi BPI-R64
4G with USB 4G module via USB
BPI-R64 case
MTK MT7622
  • 1G DDR3 SDRAM
  • MTK7615 4x4ac wifi (option)
  • support 1 SATA interface
  • (1) USB 3.0
  • POE function support
Hardware Revision
SDRAM 1 GB DDR3
SATA support 1 SATA interface
USB 1 USB 3.0 host
Buttons Reset button
IR PIN define with GPIO
DC Power 12V/2A with DC in
Sizes 148 mm × 100.5mm
Weight 100g
PoE support
more PoE module spec
4G support
BPI-R64 GPIO Pin define
  • BPI-R64 schematic diagram
Amazon AWS Greengrass
Release
OpenWRT & LEDE
google driver : https://drive.google.com/file/d/1u8r_cghfu-w67CsXWTGrd7MlImuMYixx/view?usp=drivesdk
Boot media: SD Card
Fetures Map:
Fetures Map:
AArch64 Linux
Fetures Map:
